Aerostar Ford Aerostar
Airbag light,, again. Diagram help
Old 10-19-2017, 08:30 PM
sittinguy's Avatar
sittinguy
sittinguy is offline
Does someone have the code list, and the sensor locations for a 92.
I replaced the clock spring a while back, and recently got a new module. Finally had a clear dash, it worked! Its been a couple weeks and I got some flashing the other day. Its gone now. But I want to look into it. It was either a 24, or 42 code.
I don't want to get the black tape back out.
Old 11-19-2017, 12:45 AM
geoffstevens79's Avatar
geoffstevens79
geoffstevens79 is offline
might not be what you're after
I had the beeps of the backup airbag failure alarm that would intermittently beep at me for hours. Drove me even more nuts than I already am. My solution was to unplug the airbag control module.
Of course, this disables the airbag, but I'm satisfied with my choice and can foresee no possible negative outcomes. Anyway, should you want to do same, it's a blue-green box on the left wall of the car, about 1 inch above the black box that has the fuses. Disconnect the white plug. No more beeping. See crappy picture of my crappy solution.
Old 11-19-2017, 01:04 AM
geoffstevens79
on re-reading your post, it seems i didn't read your post before i posted. You likely know where your module is and how it works, given that you replaced it. You also seem to want to solve the problem properly.
My 94 has three crash sensors. one is right behind the 'ford' emblem on the grill, right in front of the radiator. second is by the driver's left foot, behind a piece of plastic trim. third i believe is in a mirror position, where passenger's right foot would be.
I have a proper shop manual of the vacuum and electrical somewhere. if you need, I can photo the pages and send.
Old 11-19-2017, 10:22 AM
sittinguy's Avatar
sittinguy
Thanks, I had my module unplugged for years because of beeping, finally took the chance on spending the money on the module once I replaced the clock spring and got my horn and cruise back. The light has been blinking more lately,, its a 24 code, and I think that may be the front sensor. But I have gotten some conflicting info looking for code 24. But THANKS for the location info I will be looking for it today. Its not beeping at me, but still bugging me. The weird thing is it seems to stop flashing after about 15 minutes of driving. I thought maybe low battery? Its a newish Interstate battery and I charged it all night the other night and it still did it.
Old 11-19-2017, 11:55 AM
geoffstevens79
can't speak to your wiring short, but my horn and cruise still work having only disconnected the white plug. Looking for that wiring diagram...
Old 11-19-2017, 12:33 PM
geoffstevens79
Old 11-19-2017, 02:26 PM
sittinguy's Avatar
sittinguy
what book is that out of?
Old 11-19-2017, 03:09 PM
sittinguy's Avatar
sittinguy
Found it! so for now I took it off, cleaned it and bolts, inspected wires, and pulled the connector plug apart behind the drive headlight and it looked good and clean(yes I disconnected the battery)
So in the morning we will go to work and see if it helped. I can replace the sensor. I'm just not 100% sure that is what code 24 really is.
I found this,,,
Fault Code 24-Safing Senor Diagnostic Circuit Open Or Low Resistance in a Primary Crash Sensor
On this site,,,
https://www.scribd.com/document/1423...ode-procedures
Old 11-19-2017, 03:18 PM
geoffstevens79
"ford technical publications vacuum and electrical troubleshooting manual"
it's wonderful, especially for someone who is a novice, but is in love with his aerostar.
even more useful is a Bishko repair manual i got on CD-- covers drivetrain and body of 1994 ranger, explorer, and aero. puts chilton/haynes to shame.
I could send copies of the bishko to you if interested.
Old 11-19-2017, 03:47 PM
sittinguy's Avatar
sittinguy
Yes, I would love a copy, how can get a copy? The pics of the pin setup you posted is just slightly to small for me to read when blown up. Could you send me a better pic somehow? The next step is going at the pins and wires to troubleshoot. I could PM you my email
Old 11-19-2017, 03:56 PM
geoffstevens79
Old 11-19-2017, 04:00 PM
sittinguy's Avatar
sittinguy
I found a copy of the elec/vac manual on ebay for $8. I got it on the way.
geoffstevens79
sittinguy's Avatar
sittinguy
Oh that pic works!! thanks
Old 11-22-2017, 02:41 PM
sittinguy's Avatar
sittinguy
Been 3 days since I found it, cleaned it, remounted it, inspected wiring, and reseated the plug. and,, NO LIGHT!! YEAH
Thanks all for the help!
Quick Reply: Airbag light,, again. Diagram help
