Transmission and OBD port issues. - Ford Truck Enthusiasts Forums
Old 10-19-2017, 06:39 PM
hellssorrow hellssorrow is offline
hellssorrow is starting off with a positive reputation.
Hey fellow FTE'ers, hope you guys are doing better than I.
The truck: 1999 F-250 LD XLT? 4WD, 5.4 Gas 254221Miles, 4R100 rebuilt less than 10 miles,Tow package.
The problems:
1. Transmission will not shift out of 1st gear, drives forward in Neutral, drives forward with reverse lights on in Reverse.
2. No speed read out on speedometer, it doesn't move at all. Transmission does have both speed sensors in it and plugged in. Worked before transmission rebuild.
3. OBD port has no power not does the cigarette lighter port, yes the underdash fuse F3 was good, replaced it with a new 20A fuse that was tested before installing it.
Background, transmission was rebuilt by a friend who owned a transmission shop and retired. Unfortunately he passed away from a PE last week, so I'm on my own. The day the transmission was installed it worked like a dream, all gears worked fine, 2nd day the problems as stated above. I got a OBD scanner to try to see codes, but problem 3 is stopping me. I'm not afraid of doing work, my issues are knowledge, tools, money, and time, but isn't that everyone's. Being a volunteer firefighter and EMT student doesn't help the time & money. Any knowledge or suggestions on these problems are greatly appreciated. Also, assume I have basic mechanical knowledge and limited tools. If you guys need any more info on the truck let me know. Thank you.
Old 10-19-2017, 08:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
There are two ways I can see it moving forward in every position. One, the manual valve inside the pan isn't properly connected to the linkage, so that when you're moving the shifter the manual valve isn't moving.
Second, the forward clutch could have failed.
With the shifter in park and the engine off will the truck roll, or does park hold?
Old 10-19-2017, 10:10 PM
Thanks for the reply Mark.
With the engine off in park it will hold without the parking break engaged, but will roll in R-N-D-2-1.
I'm guessing if the forward clutch failed, it/s either a bad rebuild or defective part as the truck has about 10 miles on it with the rebuilt transmission, am I correct?
I'm spent $800 on the rebuild and would hate to have to get it done again, especially since it's 42 miles to the next closest shop and with the truck down I got a motorcycle as my daily driver.
Is there any thing else it could be or any additional test I can do? just want to be as sure as possible.
Thanks again Mark.
Old 10-20-2017, 06:14 AM
Yes, you could take the pan off and see if the linkage is connected to the manual valve.
Old 10-21-2017, 09:05 PM
Mickey Bitsko Mickey Bitsko is offline
Mickey Bitsko is starting off with a positive reputation.
Not being snarky or a smart azz, I would bite the bullet and tow/trailer it to the nearest dealership or most highly recommended transmission shop and have every issue addressed and get on with life.
In reality, getting any transmission rebuilt properly for$800 is a steal. Even a few hundred more is still a good deal.
Just my .02
Mickey
1996 F-350 starts, Idles ok, no power, won't accelerate, bogging down Brentburek 1987 - 1996 F150 & Larger F-Series Trucks 2 07-27-2017 06:50 PM
98 f150 transmission issue Brandi Rogers 1997 - 2003 F150 2 03-08-2017 11:12 AM
4r100 Won't shift into 3rd sometimes. At a bit of a loss. Millinex Clutch, Transmission, Differential, Axle & Transfer Case 0 10-23-2016 07:15 PM
02 Ex: Throttle Blips, engine cutouts... DTC's included Jesser02EX 1999 - 2003 7.3L Power Stroke Diesel 11 09-16-2016 10:31 AM
Stumped! HaulStroker 1968-2013 Full Size Vans 3 12-24-2015 12:06 PM
Tags
obd, shift, speedometer, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
