Weird "sloshing" sound?
This could be coincidence, but I never heard it until after I completed the TSB on the fuel tank.
When I go over a speed bump, or rough terrain and come to a stop, and I have the radio off and it is silent, I can hear what is best described as what I would assume to be fuel sloshing. Imagine a "louder" back and forth rocking that eventually quietens down until you can't hear it anymore. Has anyone else heard this sound? I know it's easy to become paranoid after someone else works on your truck, but I don't recall hearing that sound before I did the TSB, and I want to make sure they tightened everything down the way it is supposed to be. Thanks guys!
tortue71, thanks for the reply. Paranoia is a tough animal to kill!
You aren't kidding!! This is my first diesel, and I am fascinated at how quiet it is. I'm glad to hear I'm not the only one hearing it though, so now I know there isn't something loose knocking around in there. All I could imagine was the fuel pump or something floating around in there, and that is what I am hearing...I know, I know...that doesn't make any sense at all.
I kept hearing the same thing. Then found out that my passenger side rear door was half way full of water. The drain holes were full of lithium grease from the factory and it couldn't drain. You may want to check them to be sure the sound isn't a little closer than your fuel tank.
Weird Sloshing sound
Just picked up a new F350 Crew Cab.
Was not even out of the lot when the passenger noticed a "sloshing sound" when breaking or accelerating.
Looked for typical clogged drain holes in doors, but both front and back doors have open drains and are dry inside.
Took out the floor mats this morning to find moist carpets on passenger side.
Took off the rocker panel covers to expose the wire tray and found the passenger side tray full of water. (Divers side is dry)
This is my first truck with a moon roof,. so I suspect it may be the moon roof drain, but have nothing to back up that theory.
I'm wondering if anyone out there has any insights they could share with me.
The saddest thing is I have no faith in the dealership fixing this correctly, This seems like one of those problems that because they can't throw new part at it, it wont get fixed properly. (I can imagine them simply drilling a hole for the water to drain, rather than find the source of the problem and addressing that )
Then x years from now I'll be dealing with corroded wires and fuse box.
I'll try to attach a pic below.
Water in rocker panel wire tray. 2019 Ford F350
One piece of advice, is to check the drains on the corners of the roof. They tend to clog easily. There's a lot of glass up there to dump water into them. Good luck.
Your rocker panel leak may be from the moisture barrier in the doors not being completely sealed. Take a look under the door panel and sometimes you can see where the water droplets ran down from behind the door panel. The water will accumulate on the trim panel you removed to take your picture and then run into that valley. You can also let a water hose run right at the bottom of the window and the leak will usually show up in a couple of minutes or less.
Sloshing sound
Does anyone out there know where / how the water from the sun roof is supposed to drain?
I ran a hose on the roof for a while and found how it's getting inside the truck and down into the rocker panel.
What's best described as the door jam has a rather large hole where a wire harness comes through which goes into the fuse box mounted near the passengers feet.
The harness passthrough a boot which is made of foam rubber.
That boot is not glued or otherwise fastened to the door jam.
The water is running down within the door jam and coming through where the boot goes into the jam.
I managed to get a finger in there and found that below the boot - the jam seems to be factory-filled with some kind of sprat foam..
(keep in mind this truck is 4 weeks old, so nothing other than factory installed exists)
So my questions right now are as follows:
Should the water be in the door jam at all?
If yes, should the bottom of that door jam be filled with foam (or filled with so much foam) that the water can't exit and builds up until its high enough to come through =the hole with the boot?
(see pic attached to this post)
I just found out I have the same issue but it is on the driver side.
I do not have a sunroof but I do have clearance lights on the 2019 F350 STX 6.7 CC LB. I also have a sliding rear window opening.
I first noticed when I lowered the backs of the rear seats and saw rust on the hinges. Like it's been happening for a while.
This is from the rear driver side door.
