1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Parking brake adjustment?
Old 10-16-2017, 01:01 PM
doc4bax's Avatar
doc4bax
doc4bax is offline
2003 Expedition EB 5.4L. Is there a way to adjust the parking brake cable? I know you can adjust the shoes which is a PITA. I've done that and it helped them grab a little better but it feels like the cable needs to be adjusted.
Old 10-17-2017, 01:02 PM
Hamfisted's Avatar
Hamfisted
Hamfisted is offline
The correct way is with a caliper.
There is no cable adjustment point.
If you have the larger size caliper it's pretty easy to do it right. Use a .013" -.016" clearance and they should work like new.
-Mike
Old 10-25-2017, 07:29 AM
BAD RONALD's Avatar
BAD RONALD
BAD RONALD is offline
I did a rebuild on my '01 when the passenger rear wheel seal failed. New everything BUT the e brake cable. I spent a long time trying to adjust the e brake to hold the Expy in drive at 2000+ rpm. I was unable to do so to my satisfaction. I suspected at the time I was dealing with either a stretched cable or a parking brake design that was over matched by my test.
When I took the parking brakes apart I found hardware that was frozen by rust (I know this is hard to imagine on an Expedition). This on both sides, not just the side with the leaking seal. I decided to accept the best adjustment I could manage and use the parking brake frequently to keep it from seizing up again
bagman1995
03-23-2018 06:58 PM
ptaylor-01
04-22-2010 04:04 PM
bad_habit59
02-12-2009 12:20 PM
Carmen10
1997 - 2003 F150
12-30-2008 06:40 PM
supersonicss
02-13-2006 12:36 AM
Quick Reply: Parking brake adjustment?
