1980 F100 300 3spd column to T18 / T19 swap idea
Old 04-11-2019, 10:29 PM
brendo613's Avatar
brendo613
brendo613 is offline
brendo613 is starting off with a positive reputation.
Rembrant, you lucked out! Attached is a picture of the 3spd transmission's cable installed and held below is the pink colored T18's cable.
Fuzzface2, from BorgWarner T-18 Transmission Specs & Ratios, "Fluid Type/Spec: 50W motor oil, 80W-90 gear oil, non-hypoid, low sulfur." Multiple posts list 50W as delivering superior shifting as well. The donor truck's speedometer cable was cut during trans removal. If only! A new one is on order at the local NAPA, at least.
Old 04-11-2019, 10:42 PM
can0fspam's Avatar
can0fspam
can0fspam is offline
can0fspam is starting off with a positive reputation.
For what it's worth, I'm pretty sure I've heard that 50W oil is no longer the same designation as 80W90 gear oil -- also that newer motor oils contain additives that will make it foam when put into a transmission.
I would recommend using 80W90. GL4 if you can.
Old 04-12-2019, 09:33 AM
brendo613's Avatar
brendo613
can0fspam, that is a good point - 50W is not designated gear oil. Here is some information about the 50W I purchased:
Features & BenefitsVR1 Racing lubricants are the leading-edge of racing oil technology formulated to increase horsepower and protect high-performance engines during race conditions, providing the competitive advantage professionals and racing enthusiasts seek. VR1 Racing lubricants is the right choice for both road or track.
  • Superior friction reduction boosts horsepower output
  • Maximum performance and protection at high temperatures
  • Extra anti-wear additives (ZDDP) provide ultimate wear protection
  • Excellent oil film strength to improve durability
  • Enhanced additives protect against deposits and fuel contamination
SpecificationsContainer Size1 qt (US)
Manufacturer Part Number822350
Motor Oil Style and TypeConventional
UNSPSC15121501
Weight Rating50W
Old 04-12-2019, 10:52 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
FuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to all
I would check what temp that W50 is rated for.
I bet it is for winter temps and not summer.
There was a post a few months back of a hard shifting trany when it was cold. Once it run for a bit and warmed up it shifted fine.
I think he went with a lighter weight oil and it shifted fine but was going to go back to the W90 when it warmed up.
Dave ----
Old 04-12-2019, 01:23 PM
can0fspam's Avatar
can0fspam
I would not use any modern engine oil in a transmission. The additives make them foam and do other weird things -- which engine oil never used to do, back when Ford applied the 50W designation to these transmissions.
I'm pretty sure Ford even officially changed away from the 50W designation retroactively, after motor oil started changing.
I know you've already bought the oil -- but I would definitely go for a GL-4 80w90 if it was my transmission.
Old 04-12-2019, 03:07 PM
brendo613's Avatar
brendo613
FuzzFace2 & can0fspam, points taken. How about Lucas Oil 50 WT Transmission oil?
https://lucasoil.com/products/transm...0-wt-trans-oil
Old 04-12-2019, 04:22 PM
FuzzFace2's Avatar
FuzzFace2
I would use that over the motor oil in my trany.
I will have to see how mine shifts but from what I remember it was not bad and we don't get that cold down here and if so it is not for long.
Only thing I don't like is it comes in a gal jug & larger.
Dave ----
Old 04-12-2019, 04:31 PM
brendo613's Avatar
brendo613
More for later, then!
Old 04-12-2019, 04:36 PM
FuzzFace2's Avatar
FuzzFace2
But hope you don't need it later.
Dave ----
Old 05-05-2019, 08:32 AM
brendo613's Avatar
brendo613
Wanted to thank all involved for the advice along the way. Since I use the truck for business (lawn and garden equip repair), and since business has been very busy, it is still a 3 speed ... here's looking forward to letting you all know how the swap goes
pogo619
11-12-2017 07:27 PM
minnesota-clint
01-16-2015 08:47 PM
1970RangerXLT
02-18-2013 07:12 PM
merten
13
10-05-2009 01:32 PM
bill11012
06-14-2009 10:54 PM
Quick Reply: 1980 F100 300 3spd column to T18 / T19 swap idea
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
