Does anybody know what color the SWI 2 wire is for snyc input? its says i need to check with a meter which i dont have dam u crutchfield
One site I use that enables you too look up wiring diagrams for free ( you just need to register for a free account) is BBB Industries- Premium Alternators, Starters, Power Steering Products Just go to Technical Information and then at that menu you will see TSB's and Wiring diagrams click on that and select your vehicle info and you should be able to go thru and find the appropriate wiring diagrams for what your looking for
