Anyone regret the longbed?
Had a '15 F250 CCSB. Decided to get a '17 350 CCLB for the bigger tank, no need for a slider hitch, more room for stuff. I daily drive it and park in a parking garage. With the long bed, I have to park on roof, out of the way of others as it sticks out into the aisle and I'm convinced someone will hit me. I can't park in a single spot at any store. Overall, no regrets. Haven't towed yet.
Yes, the are a lot of garages I wouldn't even try, but the one at work is 7'6" post the first floor, which is just over 8'. That's not to say that when I first drove in that I want ducking and cringing every time I went past a concrete joist hanging down.....
Im in the Bay Area also, and even my SB can be difficult. Of course I daily drive a 4runner, so its not common to deal with. I am concerned a lot about maneuvering and backing my boat trailer, enough so I am second guessing myself even though many times I’ve said Id never buy a short bed again.
I just back into tight spots and park further away than I would in a car.
If we're headed to the city or somewhere with tight parking, we take the wife's Edge.
when your buying these trucks....whats 2 more feet? GET it, its worth the larger tank alone!
Ive owned a long bed crew cab since 2004, back when the turning radius was REALLY bad (think leaf springs up front that prevented wheel cut).
I've never been afraid to use reverse. In a long bed the tank is larger 48 gal (vs 34) and you can STILL put a tank in a long bed and barely impact the cargo space. In my 2004 I had a 50 Gallon (Aluminum add a tank) that was 10 inches deep and gave me PLENTY of room to put a motorcycle (or 2) and camping gear in the bed.
the freedom to pick and choose when & where you want to stop for fuel is huge.
The original poster is comparing a Crew Cab Long bed to a Crew Cab Short bed.
when compared to OVERALL Length a Crew Cab LONG bed is only 16 inches longer than a Crew Cab SHORT Bed (250" vs 266..2")
Titan's 55 gallon (factory replacement) tank will cost you $1200....which is $57 per additional gallon capacity - for that added 21 gallons.
TransferFlow 60 gallon (factory replacement) tank will cost you nearly $1600....which is $62 per additional gallon - for that added 26 gallon.
You can add a tank in the bed of the truck of at least 50 extra gallons for 600 bucks (12 bucks per additional gallon) or less if you want the ATTA 40 Gallon And you have the freedom to go up to 100 gallons more if you can afford the space (of 22").
You can add an automated fill system to any tank (pump and gauge included) and still be under 1000 bucks (complete) or 20 bucks per additional gallon....and you'd still have more cargo space (in the bed) than a short bed....because you'd only give up 10-12 inches of depth.
To each their own - but the in bed tank is easily removed and re-sold or re-installed in the next truck.
#29
and I'm just pointing out that a LONG BED can have MORE fuel capacity and STILL have more (cargo) capacity than a shorted WITHOUT a tank in the bed.
#30
I don't remember me mentioning anything about a tank in the bed. I was talking about a replacement tank. Which there isn't one available for the long bed and there is for the short bed. So a short bed can have more fuel capacity than a long bed without adding a tank in the bed. And I can still park easier and haul everything an LB can as well as much weight.
