Diesel Fuel filler neck and sending unit
Thanks but those appear to be parts for a gas engine vehicle. Would you or anyone have the Dorman part number to search for for a diesel?
Does any of the aftermarket make a fuel pickup or is a $400 oem one the only real answer?
Does anyone know the hose diameters for the fill and vent tube so I can order in a length of fuel resistant hose?
Thanks for the help.
The filler neck on my 01 diesel (and the vent tube) are flexible rubber hoses. They are NOT that metal piece for $281 on eBay posted above. It could be that someone replaced mine with an aftermarket option prior to my purchasing it.
https://www.fordpartsgiant.com/parts...z-9034-aa.html
YC3Z-9275-AA is the part number Ford comes up with and I cannot match that to a Motorcraft number or find one for less than $400. Wish I knew the difference.
if I may ask, Are you after the fuel sending unit or the pickup part of the assembly ?
Is your filler neck assembly out of the vehicle yet ?
Have you tried the local recycling yards ? I just picked a roof rack up yesterday off a gas Ex. I can see if the filler neck is still in it. ( it is pretty complete )
I'm sorry. I looked it up for my 03.
I would guess all these parts except the sender would interchange since all X's used the same fuel tank regardless of fuel type. For the sender I would guess no difference between 6.0 and 7.3 as it appears they used the same foot.
Looking at rock auto for 01 X I now see your predicament.
Both. I need to replace the original pickup and the fuel gauge has been flakey so should put a new sending unit in while I have the tank down. Same for the filler neck, its not yet leaking but it don't look great so going to replace it while I have the tank down along with the hoses connecting it.
Gas Ex filler is different from the diesel one. I think its tube size but not positive but the part numbers are indeed different.
Has someone here installed the gas part in a diesel truck and can comment first hand experience?
For the filler neck, I'd be interested in a used one in good shape, IE not rusted. The pickup and sender I really want new.
Also I know the pickup screen is available as a separate part. Is the float and sender? The flange and tubing is likely just fine.
When I did my diesel conversion I just used the v10 filler and knocked out the plastic restrictor for the gas nozzle. Now I have the hole the same size as the pipe. Cap fits on the same, though its not a green one.
If you can live with that difference, you might be all right.
mudmagnet63
17
06-01-2016 05:34 PM
alchemist1
16
07-20-2012 01:03 PM
