o d light flashing with brand new shift lever is still flashing 2001 f350
Flashing OD light means you have a transmission issue, replacing the shift lever will not make it go away. You will need to get the codes read by a good transmission shop to identify the problem in the transmission, or purchase a scanner that works with your vehicle.
No way to check
Several years ago I bought the truck used and the code reader has never worked so I need to try to fix it on the fly. I had already installed a new shift lever with O/D. I've now flushed the tranny and it has the right type and the right amount in it. I have also wrapped every wire with electrical tape. It still will start flashing if I stop and idle, ie: stop light. As long as I can keep it rolling nothing happens but when it is in the blinking mode the only way I can get it to go forward is to floor it. At the times the light blinks, I turn it off and re -start it which is horrible in the traffic I have to drive through, 1:25 and 1-70 in Colorado, please help me if you can. Thanks, Leslie Kennedy
If you can't read the codes that are stored all anyone can do is guess. I can list a bunch of parts and you can buy and install. Eventually, you'll probably get lucky and replace whatever is causing the problem.
Or you could get the codes read with a different reader and we could send you right to the problem. Your call.
A quality scan tool is worth it's weight in gold when it comes to these trucks. Especially for transmission codes. You will save yourself a lot of time and money by getting the code read that is already stored. It will tell you what is wrong, or at least point you in the right direction.
rollinginmudgirl
11-05-2009 05:58 PM
talldog
12-02-2002 06:13 PM
