Tearing out the old headliner
Old 10-13-2017, 04:06 PM
56 George's Avatar
56 George
56 George is offline
I bought a new interior kit from LMC and thought i would start with the headliner and work my way down. I tore out the old headliner that had the stereo mounted in the roof. There was no insulation previously except this white cotton like material in thr forward section. Not sure what that is. My question is has anybody used Roxul home insulation on the roof? It's fireproof, waterproof a good sound deadener and insulation all in one. Also, if anybody has advise for installing a bow style headliner in a 56 F100 please let me know, thanks.
Old 10-13-2017, 06:48 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
I would say that is a mouse nest! Check your seat for missing padding.
It looks like the PO glued that headliner onto the original cardboard headliner.
Old 10-13-2017, 06:51 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
[QUOTE=abe;17524681]I would say that is a mouse nest! Check your seat for missing padding.
That's why 56 roofs rust out! Mouse Pee!
Old 10-13-2017, 06:59 PM
49f3dls's Avatar
49f3dls
49f3dls is offline
It looks like the previous owner used cotton batting often used in the seat cushions. If it is mouse nests you would see a LOT of droppings for that size nest. It probably should not be used as it needs to breathe better or it will hold moisture and cause your rust problem. Have fun sanding the roof.
Old 10-13-2017, 07:12 PM
56 George's Avatar
56 George
Right it was glued to cardboard.
I'm not sure if it was the original cardboard or not but you are correct the headliner was glued to the cardboard. The picture makes the rust look worse than it is. I think a light sanding and paint will be just fine. Just trying to decide on insulation or not. Thanks for the reply.
Old 10-13-2017, 07:59 PM
abe's Avatar
abe
abe is offline
I would use some type of insulation. That metal roof transmits a lot of heat on a hot sunny day.
Old 10-14-2017, 08:38 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
2X using some sort of insulation in the roof. It helps with both heat and reducing noise.
Old 10-14-2017, 09:05 AM
56 George's Avatar
56 George
ya, I'm looking at options now. Is there one product that works good for both?
Old 10-14-2017, 02:13 PM
abe's Avatar
abe
abe is offline
there was a thread on this not too long ago.Do an advanced search and you should find it.
1984_IH6.9_Project
01-24-2017 08:50 AM
The Hill Boys
26
01-10-2016 09:49 PM
raytasch
11-11-2011 09:06 PM
Ford_Six
General Automotive Discussion
01-21-2010 03:19 PM
slayercr23
35
08-14-2009 11:16 PM
Quick Reply: Tearing out the old headliner
