Sending Unit for Mustang Tank - Ford Truck Enthusiasts Forums
Old 10-13-2017, 03:21 AM
1949f1's Avatar
1949f1 1949f1 is online now
1949f1 is gaining momentum as a positive member of FTE.1949f1 is gaining momentum as a positive member of FTE.
I have searched through all the post on using the mustang tank in my 1949 F1. I didn't find anything showing what fuel sending unit to use for aftermarket gauges. I found one post where he added one to the top of the tank and took out the stock unit and left just the feed tube for supply of fuel but he didn't say what he used. I may have missed a post but don't know. Thanks
Old 10-13-2017, 04:38 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
You need an aftermarket gauge that is compatible with the stock Mustang sending unit.
Old 10-13-2017, 06:00 AM
rico56's Avatar
rico56 rico56 is online now
rico56 has a good reputation on FTE.rico56 has a good reputation on FTE.
Hi Tracy,
there are two ways you can make this working. Either using a sending unit and gauge compatible to the mustang tank (that means you can order that parts in a Mustang shop such as Summit or Rockauto....). But theese parts need 12V! Or you keep your stock gauge, buy a stock sending unit and mount this on the top of the mustang tank. This way you'll need to calibrate the stock sending unit by bending the arm of the sending unit or by interposing a resistor. Not an easy way and not as accurate as the first way, but possible.
That's
Old 10-13-2017, 06:31 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Tracy,
We put a new 22 gallon '70 Mustang tank in our truck with modern
Autometer gauges. We had to use the Mustang tank's sending unit
to get the unique fuel pick up that fits that tank. We then bought a
second universal sending unit that was compatible with our gauges ...
just soldered the universal unit's sending unit onto the '70.
I hope that helps. You basically buy (2) sending units & & solder the universal
one onto the '70 ....it's pretty straight forward and luckily the universal ones are pretty cheap.
Ben in Austin
1950 F1
Old 10-13-2017, 06:51 AM
ben73058's Avatar
I also saw a discussion on here about a Sending Unit that
can be used with all the different types of gauges. I'll see if I can
find that link.... not sure about the price.
Ben in Austin
1950 F1
Old 10-13-2017, 07:05 AM
special 55 special 55 is online now
special 55 is starting off with a positive reputation.
Hi Tracy,
I used the mustang tank and sending unit in my 52. My modern gauge set is from New Vintage. They fit the standard opening in the dash as I didn't want to cut that up at all.
If you contact them directly and tell them what ohm range sending unit you have they will build you a set of gauges with the proper fuel gauge.
Very nice people to deal with and they back their products.
Good Luck with your project.
Old 10-13-2017, 07:26 AM
ben73058's Avatar
Hey Tracy,
Here is the link to the Mustang Tank fuel sender discussion....
droptop46 lays out exactly what we did with our tank sending unit.
https://www.ford-trucks.com/forums/8...stion-12v.html
Ben in Austin
1950 F1
Old 10-13-2017, 01:25 PM
1949f1's Avatar
Thanks for all the help. I have a friend that sells mustang parts and giving him a call about a tank today. Auto meter's web site claims to have a gauge that will work with the 73-10 ohm sending unit. If not I will do the combining of the two sending units and see how that goes.
Old 10-13-2017, 04:44 PM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to behold
I used an autometer gauge with the ford ohm sweep and it works fine. Speedway motors also sells a module that somehow converts the sending unit signal to whatever ohm range your gauge is. Not sire how well that works though.
16 gal midship tank sending unit? Dr. Johnny Fever 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-05-2017 07:54 PM
Fuel Gauge Reading E kevinmcc2 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 06-16-2017 10:29 AM
need proper sending unit for 38 gallon Spectre Fuel Tank highoctane74 Fuel Injection, Carburetion & Fuel System 4 03-24-2017 12:18 PM
Sending unit question Osoford 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-08-2017 10:00 PM
fuel sending unit Help! fordtruckguy98 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-12-2016 06:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
