question on fuel line quick disconnects - Ford Truck Enthusiasts Forums
Old 10-12-2017, 09:39 PM
jstihl jstihl is offline
jstihl is starting off with a positive reputation.
Hey guys , i need to disconnect the fuel lines from my sending unit and have noticed from looking at different threads that alot of people had a hard time with the quick disconnects. i just have an old metal fuel line disconnect tool in the tool box which i believe is 5/16 on one end and 3/8 on the other. will that work or is there other ones that are better( plastic, etc..). Thanks for any input
Old 10-12-2017, 09:44 PM
Colorado350's Avatar
Colorado350 Colorado350 is offline
Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.
I just used the disconnect tool when I did my pump, worked fine. But I think I swore 3x before I started for good measure.
Old 10-13-2017, 04:22 AM
Tugly's Avatar
Tugly Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
I've used everything from the plastic tool purpose-made to a small screwdriver. My difficulty was never to get the QDs apart, but to get them to seal on a vacuum (fuel line).
Old 10-13-2017, 06:39 AM
Ok thanks guys, guess it's not as bad as it was made out to be.
Old 10-13-2017, 07:23 AM
pirschwagon pirschwagon is offline
pirschwagon has a very good reputation on FTE.pirschwagon has a very good reputation on FTE.pirschwagon has a very good reputation on FTE.
Quote:
Quick shot of WD-40 or similar makes both connecting and disconnecting much easier. For that matter, any disconnect tool operates better in a knurled connection with some lubricant.
Old 10-13-2017, 10:20 AM
Quote:
thanks for the great advice, I will just need to remove them as I plan on eliminating the quick disconnects
Old 10-13-2017, 08:27 PM
Whitey Ford's Avatar
Whitey Ford Whitey Ford is offline
FTE-Spread The Knowledge
Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.
Makes you wonder why they call them “quick.”
Old 10-14-2017, 01:19 AM
Keabler's Avatar
Keabler Keabler is offline
Keabler is starting off with a positive reputation.
I removed all of the quick connects on the fuel system, at least on the suction side. (of course I didnt tighten the compression fitting when doing the hutch mod, so had to go back in.) I like not having the quick connects much better. Especially having had to disconnect twice.
Old 10-14-2017, 07:28 AM
Syncrowave's Avatar
Syncrowave Syncrowave is offline
Syncrowave is gaining momentum as a positive member of FTE.
Quote:
No kidding. I've found that they require every bit of brute strength you can muster, in about 15 attempts, to get apart – when they suddenly part and you knock your own teeth out with your hand when they release.
Is there ANYTHING on these trucks that doesn't require a 15,000 ft-lb impact wrench, sledgehammer, oxy-acetylene rosebud and plasma cutter to disassemble? Opening the glove box, maybe?
Old 10-14-2017, 08:09 AM
sounds like i have a fuuuunn afternoon ahead. ha!
Old 10-14-2017, 06:01 PM
Syncrowave's Avatar
Wellllll, my truck is kind of a "special needs" truck, since it came from the Salt Belt and apparently didn't have the salt rinsed out underneath EVEN ONCE IN 15 YEARS ... but I wish you luck!
Fuel Line Disconnect Raymond 1999 to 2016 Super Duty 3 01-16-2018 06:06 AM
Tool Dimensions? Splash67 6.0L Power Stroke Diesel 11 08-06-2017 09:00 AM
Rear Fuel Line Removal garydmundy 1999 - 2003 7.3L Power Stroke Diesel 5 07-23-2016 06:21 PM
Transmission Cooler Line HELP!! mattf76 Modular V10 (6.8l) 3 05-04-2016 11:48 AM
Transmission Cooler Line Help!! mattf76 1999 to 2016 Super Duty 13 04-29-2016 10:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
