Loard max, and Axle Ratios ? tank you. - Ford Truck Enthusiasts Forums
Old 10-12-2017, 07:52 PM
guy lavoie guy lavoie is offline
guy lavoie is starting off with a positive reputation.
ford,2007,5.4L., 4x4 serie: 1FTPX14V27FB49569
Old 10-12-2017, 08:06 PM
watts is maximum charge and Axle Ratios ?
We have Ford 2007,5.4l. , xlt 4x4 series:1FTPX14V27FB49569
Tank-You for you help.
Guy Lavoie
Old 10-13-2017, 12:37 AM
Tx.Hoon Tx.Hoon is offline
Tx.Hoon is starting off with a positive reputation.
It might help if you post in this forum: https://www.ford-trucks.com/forums/forum24/
The one you posted in is for 2015+ models.
Old 10-13-2017, 08:39 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
your on the right forum.......... click on your serial number and you will be directed to a generic page with data from a 2007 model.... there are a few different axle ratios that can give you more or less max weight rating.. the axle ratio (CODE) is listed on the drivers door post, and also a tag bolted on the rear axle pan cover... Get the two digit code and we can give you the ratio.
Old 10-13-2017, 08:42 AM
steve(ill)'s Avatar
some common codes
19 – 3.55Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
