No turn signals - Ford Truck Enthusiasts Forums
No turn signals
Old 10-12-2017, 06:56 PM
Tyler brouwer Tyler brouwer is offline
Tyler brouwer is starting off with a positive reputation.
No turn signals
ive been working on my 79 f250 now and havenít had turn signals the hazards work but signals donít. Any ideas?
Old 10-12-2017, 10:38 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Fuses, bulbs, power to the sockets, turning signal flasher, good grounds? I bet you need a new t/s switch on the column.
TSF is a round plug in elec item, attached to the rear of the left hand inner cowl side panel near headlight switch. (up under and behind the dash).
Old 10-13-2017, 05:39 AM
Sorry I forgot to mention I replaced the turn signal switch
Old 10-13-2017, 08:18 AM
HoustonDave HoustonDave is online now
HoustonDave is starting off with a positive reputation.
So that leaves "fuses, bulbs, power to the sockets, turning signal flasher, good grounds" also check power TO the T/s switch.
Old 10-13-2017, 12:33 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
TWO different flashers, two different locations. Both are round with 2 prongs, but the 4 way flasher is a H/D unit, has a louder CLICK
No brake lights or turn signals dwcford 1961 - 1966 F-100 & Larger F-Series Trucks 26 07-18-2017 10:38 PM
Turn signals not working when HVAC is on Hound Dog Lew 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 06-26-2017 10:46 AM
turn signal doesn't work when lights are on BigCountry1978 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-02-2016 12:14 AM
No turn signals 51camohunter 1987 - 1996 F150 & Larger F-Series Trucks 15 06-30-2016 11:02 AM
Turn signal problem Bradley Ripley 1999 to 2016 Super Duty 1 02-22-2016 10:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
