A FEW QUESTIONS ON SOME F150 OPTIONS: 2011-2015 - Ford Truck Enthusiasts Forums
Old 10-12-2017, 03:10 PM
jaygee15 jaygee15 is offline
jaygee15 is starting off with a positive reputation.
I know this is the 09-14 section, but I am considering trucks between 2011-2015 if I might be able to find a good deal on a 2015 that I can afford. I have a few questions I hope you guys might be able to answer to help narrow down the truck I am looking for. I will be using the truck for some daily driving, camping, towing, offroading, etc purposes. I also want the ecoboost engine. So here are my questions.
Does only the fx4 come with a locking rear diff or can you get a lariat , platinum or king ranch with one also?
When did the 10 speed tranny get introduced? how does the 6 speed stack up against it?
are there any years with known issues that I want to avoid?
Which models or years have the shift **** on the center hump, I don't like the ones with the bench seat and shifter on the column?
which models have the full selection of 4x4, auto, hi, and low?
Thank you , and any other advise is welcomed. I hope to buy a truck in the next six months.
Old 10-12-2017, 04:29 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
Bleed Ford Blue
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
Replies to questions in Red
Does only the fx4 come with a locking rear diff or can you get a lariat , platinum or king ranch with one also? Locking rear axle was optional on all F-150s from XL and up 2011-2015 as far as I know
When did the 10 speed tranny get introduced? how does the 6 speed stack up against it? I've never driven the 10 speed which came out in 2017 behind the 3.5 Eco and in 2018 is behind all but the base engine. I can't comment on how it drives the but 6 speed has proven to be reliable and mostly problem free
are there any years with known issues that I want to avoid? I believe early Ecoboost trucks 2011-2012 could have a few issues that were later fixed, the vacuum pump behind one of them, otherwise '13-15 should be pretty good
Which models or years have the shift **** on the center hump, I don't like the ones with the bench seat and shifter on the column? you'll need to make sure you get a lariat or above trim and make sure it has a full length center console, that is the only way to get the floor mounted shifter, this goes for all years you are interested in
which models have the full selection of 4x4, auto, hi, and low? you will need a 2012 or newer lariat or above trim level to get the "Auto 4x4" option otherwise it will just be normal 4x4
Old 10-13-2017, 10:03 AM
Robbgt's Avatar
Robbgt Robbgt is online now
Robbgt is a name known to allRobbgt is a name known to allRobbgt is a name known to allRobbgt is a name known to allRobbgt is a name known to allRobbgt is a name known to all
Quote:
Russ, I believe the '15 XLT with sport package came with the console mount shifter as well.
Old 10-13-2017, 10:05 AM
AlaskanEx's Avatar
Bleed Ford Blue
Quote:
Learn something new every day, I'm not as well informed on the 15-up trucks.
Navigation with Forscan superdog404 6.7L Power Stroke Diesel 30 10-03-2017 04:47 AM
anybody install a 2011-2015 Ford 6.7L PSD Coolant Filtration System 99FORD EXPY. 6.7L Power Stroke Diesel 10 03-13-2017 08:29 AM
New EcoFix for 2011-2015 F-150 EcoBoost Rattle Issues edtahaney 2015+ F150 8 04-04-2016 11:30 AM
WANTED late model grille insets Leroy Unlisted 1999 to 2016 Super Duty 0 03-23-2016 02:35 AM
2011-2015 Grille question vortec 1 1999 to 2016 Super Duty 5 01-08-2016 03:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
