220amp Alternator Replacement 2008 F450 6.4L
At 150k my alternator is starting to behave badly, it probably cooked a battery which froze overnight, after replacing the battery the alternator is showing broad voltage ranges from 12.5v to 15v while driving. Dealer (70 miles away) will have one this afternoon.
My plan is to remove the passenger fender liner and pull it from the side, after reviewing the available YouTube videos this seems like the path of least resistance.
I’ll keep you posted.
The removal was about 35 minutes which entailed dropping the front of the fender liner in order to reach the alternator, and lifting the fan shroud on the passenger side enough to reach in.
I used a 1/2 inch breaker bar with a 1/2 to 3/8 reducer for the belt tensioner.
In the truck I found a no name “dynasty” 120amp alternator which obviously was not original equipment. The 220amp was about an inch longer. Everything is within reach from the wheel well, remove the three bolts, then roll it out, and then the electrical connectors.
Install was just opposite, connect the electrical connectors to the alternator and then roll it into position, install the three bolts, set the belt.
I did have an extra set of hands to manage the belt tensioner.
Install was 30 minites.
Probably even some cheaper options for OEM. Glad to hear everything went well Copper. Now we know, if we didn't already(I didn't), a reference baseline for what my voltage should be (14.6v) when everything is working well. I think mine sits a bit below 14 at like 13.9. I'll need to monitor again on a small trip and let you know. What is the acceptable range for "good" on the charging system voltage wise?
Nothing wrong with 13.9v, I suspect it is a matter of the internals on the various alternators. About 5000 miles now, all good.
Science experiment:
My truck uses one group 65 battery on the drivers side, then a bank of ultracapacitors on the passenger side. An expensive science experiment, though amazing starts when it is -20F as there is no delay or resistance on the delivery of electrons. At the moment I have 800cca on the drivers side battery and 1800cca on the passenger side ultracapacitor that weighs only a few pounds.
Science experiment:
keating8070
09-07-2010 05:43 PM
