2003 f-250 Superduty best way to mount flatbed and handle fuel filler? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-12-2017, 10:35 AM
ccaissie ccaissie is offline
ccaissie is starting off with a positive reputation.
Mounting a Knapheide 7'-6" flatbed on a regular pickup frame. I've always had difficulty in handling the new fuel fill location and hookup, the filler being too low, and creating flow issues. I've already used PT 2 x 4 to shim out the curves to a level profile.
Is it simply a matter of using a higher wooden spacer to get the body up higher to suit the new filler neck height? How high? A 4 x 4? (3.5" x 3.5").
Then the issue of maybe making a penetration in the side of the flatbed side rail to mount the filler?
Or is there a clever way to do this?
Any links or suggestions?
thanks,
c
Old 10-13-2017, 08:37 AM
Mike1 Mike1 is offline
Mike1 is gaining momentum as a positive member of FTE.
If the picture is the same as what you have, then (I) myself would probably cut the side rail, move the filler neck up and weld it back in, obviously you'd have to weld gussets on the back side after doing this so you gain the strength back in the side rail., As you stated you could also raise the bed up another 2 or 3 inches, IMO, it would make the bed too high. Another option would be to cut out a section of the bed itself and mount the filler flush into the bed but I don't know how well that would flow having to make a 90 degree turn on the neck.
Old 10-13-2017, 10:10 AM
brandon_oma#692's Avatar
brandon_oma#692 brandon_oma#692 is online now
brandon_oma#692 is gaining momentum as a positive member of FTE.brandon_oma#692 is gaining momentum as a positive member of FTE.
They are just a pain. mine has 2 locations. I use the rear and fill on the slowest setting.
Old 10-13-2017, 01:28 PM
I see. Those solutions are about what I was thinking would work...seems to be okay with a minimum of height increase....I also hear that cutting the side rail and gusseting it works.
I'll post a pic of my solution.
thanks!
C
Dump bed filler neck ideas PA74F250 1973 - 1979 F-100 & Larger F-Series Trucks 19 08-12-2017 10:08 PM
WOOD FLATBED BUILD - 3D MODEL AND CONSTRUCTION PLANS RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 425 04-13-2017 05:47 AM
Flatbed fuel filler soapboxracer.2 Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 2 03-16-2017 04:20 PM
flatbed hdman6 1999 - 2003 7.3L Power Stroke Diesel 4 10-08-2016 09:29 AM
Dent Diesel fuel filler neck question... BORDERBUM 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-29-2016 12:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
