Dry Camping/Battery Charging Questions - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 11-12-2017, 04:14 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Given that under-hood alternator temperatures are relatively constant while under-way, do you feel that a temperature-compensated regulator would be of any real benefit for us to consider?
I could see it's value under circumstances where the temperature is less constant, like a small outdoor DC powerplant. Are you referring to automotive alternators?
Pop
  #77
Old 11-12-2017, 06:14 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Quote:
Originally Posted by SDcrewzer View Post
Therein lies the problem: float voltage is lower than absorption voltage. Alternators are convenient tools for more-or-less charging RV batteries when traveling. However, whenever possible at home or at camp, I've always used a three- or four-stage TC-charger (plug-in or solar) to properly charge and equalize my RV's lead-acid batteries. Regards, Jim / crewzer
It's been a while since I did a test but as I recall it was obvious the classic "dumb" chargers are just about perfect size for the standard automotive start battery. Where people run into problems is in warmer weather and they forget to unhook it. Oops.
In winter weather though on the 6 amp setting it would eventually spool up to 14.5 to 15.2 and had a nice plateau at absorption level and then equalization if desired. It just takes a little while. The 2 amp setting was about 13.5 to 13.8 as I recall. They had this stuff figured out a hundred years ago. I can see what they did, most people need a battery charger in wintertime so that's when they get purchased and used overnight. (Maybe they should have done a little maintenance when it was still warm out.) The important thing is to size the charger (amperage) to the battery ampere hour capacity. Too small or too large both have problems.
  #78
Old 11-12-2017, 08:10 PM
dirthawg's Avatar
dirthawg dirthawg is offline
dirthawg is gaining momentum as a positive member of FTE.
I have another battery question......
I winterized my trailer a couple weeks ago, which only entailed draining the fresh water tank, filling the lines with antifreeze and pulling the anode rod and replacing it with a brass plug. After reading another thread here somebody mentioned part of their winterizing included disconnected the house battery from the trailer. Is it in good practice to disconnect the batteries or is it okay to leave them connected while shore power is available?
I have my trailer sitting in the back yard of the house and have it plugged into a 30A RV box installed on the house. Do I need to disconnect the battery or will the on-board converter keep the battery where it needs to be?
  #79
Old 11-13-2017, 08:58 AM
Tedster9's Avatar
Main thing is that it is charged. At 100% a battery will not freeze until -49F below zero or somesuch. But, a dead battery will freeze at +20F, battery is then junk.
  #80
Old 11-13-2017, 11:13 AM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
The on-board charger should tend the battery through the winter, but you will want to monitor water level if it is a flooded cell battery. Make sure it is OK when you park it and check it in January to make sure it didn't boil off. Older batteries will cook off water faster than a newer one.
If you disconnect the battery and you expect lots of freezing temps where you live, consider pulling the battery and stowing it somewhere warmer.
  #81
Old 11-13-2017, 04:29 PM
SDcrewzer's Avatar
SDcrewzer SDcrewzer is offline
SDcrewzer is gaining momentum as a positive member of FTE.
Lightbulb
Pop
I suspect that underhood temps are fairly constant under "seasonal" circumstances. For example, I would expect for summer underhood temps to be relatively high when towing and running the A/C, but winter temps to be lower, even while towing.
The Balmar regulators seem to include some cool features, including the ability to connect optional temp sensors to the alternator and battery bank(s). They are popular for marine applications; I don't know about automotive.
I retired three years ago and some of my "organic mental files" have faded. I finally remembered that Power Stream makes some interesting-looking battery-input DC-DC multi-stage battery chargers.
I also remember how I configured my last RV's battery charging architecture. I disconnected the house batteries from the tow vehicle charging circuit, which was then used exclusively for running the three-way fridge while underway. The batteries were charged from the PV array (~300W, IIRC) on top of the RV via a smart PWM charger. This worked very well.
Regards,
Jim / crewzer
  #82
Old 11-13-2017, 04:30 PM
SDcrewzer's Avatar
Thumbs up
Quote:
Jim / crewzer
  #83
Old 11-13-2017, 04:38 PM
SDcrewzer's Avatar
Lightbulb
...The important thing is to size the charger (amperage) to the battery ampere hour capacity. Too small or too large both have problems.
Yeah, my recollection is to use a charger with a charge current in the C/5 to C/20 range, with C/10 being "ideal", where C = rated battery bank ampacity. For example use a 10A charger to charge a 100 Ah battery.
For those in need a little light reading, Trojan Battery offers a very good Battery User's Guide, primarily for deep cycle batteries.
HTH,
Jim / crewzer
  #84
Old 11-13-2017, 08:13 PM
And, for those that want a LOT of HEAVY reading, there's always:
Battery Information Table of Contents, Basic to Advanced
Good luck!
Pop
  #85
Old 11-13-2017, 09:56 PM
HRTKD's Avatar
HRTKD HRTKD is online now
HRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to behold
Good luck!
Pop
I went through some of that a few weeks ago. Way more info than I can remember, but it's interesting reading.
  #86
Old 11-14-2017, 11:11 AM
SDcrewzer's Avatar
Lightbulb
Good luck!
Pop
I'll have to take a fresh look at BU's updated site. I wasn't particularly impressed with the old one (5+ years ago?).
Thx,
Jim / crewzer
Today is the day........ Karl4Cat 6.7L Power Stroke Diesel 12078 Yesterday 10:06 PM
F-350 configuration for truck camper RickJohnson 2017+ Super Duty 6 05-30-2017 08:24 PM
HiddenPower helps save a life in power outage Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 10-13-2016 05:48 PM
$8 buck oil change 17 Oaks 6.7L Power Stroke Diesel 23 03-01-2016 10:22 AM
Researching for a New Travel Trailer northwindone Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups 44 02-26-2016 04:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
