Dry Camping/Battery Charging Questions - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 10-19-2017, 12:23 PM
AMXDREAMER AMXDREAMER is offline
AMXDREAMER is gaining momentum as a positive member of FTE.AMXDREAMER is gaining momentum as a positive member of FTE.
Your fridge won't be working as hard to keep the beer cold! lol
  #47
Old 10-19-2017, 02:46 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Quote:
Originally Posted by andym View Post
If you need to stop and do laundry after two days on the road, you need to buy a couple more pairs of socks and underwear.
Agreed!
I keep twelve sets of jockey shorts and twelve pairs of new white cotton socks in the RV trailer at all times. These are just for traveling.
Rarely need to do laundry on the road.
Can't have too much of this stuff......
Pop
  #48
Old 10-19-2017, 03:38 PM
Chuck's First Ford Chuck's First Ford is offline
Chuck's First Ford has a good reputation on FTE.Chuck's First Ford has a good reputation on FTE.
10 to 15 sets of socks
10 to 15 shorts.
20 plus "T" shirts...
I do the washing after I arrive and have setup trailer.. maybe. unless I can see the bottom of the Drawer.
  #49
Old 10-19-2017, 05:33 PM
rcorkum4's Avatar
rcorkum4 rcorkum4 is offline
rcorkum4 is starting off with a positive reputation.
Towing in the snow
Quote:
Originally Posted by SpringerPop View Post
Agreed!
Pop
When towing in the snow, double up on the undershorts. 😖
  #50
Old 10-19-2017, 08:50 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is online now
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Or wear none and save the laundry?!
  #51
Old 10-19-2017, 09:07 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
You're not allowed to camp next to me!
  #52
Old Yesterday, 05:39 AM
EDC8008 EDC8008 is offline
EDC8008 is gaining momentum as a positive member of FTE.
Normally it's not bad towing in the winter, I've been back and forth with either tools or pulling the Prowler and I've only had issues twice in all my years of traveling and both of those were on the same section of I 80 between between Cheyenne and Laramie. Both times were pulling my tool trailer. If you stay on the interstates it's normally better but like I previously said sometimes the weather will get you. Just be sure and give yourself extra time and be ready to slow down and definitely give yourself extra following distance. When I was working in Canada the weather didn't stop them.
Just be advised that sometimes they close the highways or state DOT can require extra chains when towing. Also many RV parks in the north shut down in winter time or you may need a heated hose for fresh water.
  #53
Old Yesterday, 08:33 AM
JayTheCPA JayTheCPA is offline
JayTheCPA is gaining momentum as a positive member of FTE.
Find out if any of the States use brine. If so and you are on the highway when there is snow / ice in the forecast (or even after the storm passed), plan on giving the truck and trailer a monsoon type soaking from underneath to limit the corrosion that the stuff does.
Tell-tale that there is brine on the road prior to a storm is that it looks like several white chalk lines sprayed across the lane.
Just read where Vermont passed a law that barred its highway crews from using brine.
Today is the day........ Karl4Cat 6.7L Power Stroke Diesel 11808 Yesterday 06:39 PM
F-350 configuration for truck camper RickJohnson 2017+ Super Duty 6 05-30-2017 07:24 PM
$8 buck oil change 17 Oaks 6.7L Power Stroke Diesel 23 03-01-2016 09:22 AM
Researching for a New Travel Trailer northwindone Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups 44 02-26-2016 03:13 PM
Wal Mart Fuel Discount 17 Oaks 6.7L Power Stroke Diesel 8 11-02-2015 02:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
