Dry Camping/Battery Charging Questions - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 10-13-2017, 06:15 AM
Chuck's First Ford Chuck's First Ford is online now
Chuck's First Ford has a good reputation on FTE.Chuck's First Ford has a good reputation on FTE.
I have a 3600 watt Westinghouse generator..
it has a 30 amp "RV" connector on it... from the factory.
my trailer has a long cord... so generator just sits in bed of truck..(chained down)
I start generator and plug in trailer...
works well for furnace, microwave, coffee pot .
  #32
Old 10-13-2017, 06:24 AM
EDC8008 EDC8008 is offline
EDC8008 is gaining momentum as a positive member of FTE.
I came to a realization with work, at about 2 weeks of being on the road is the break even point for pulling and staying in my trailer. After that you are saving money.
That being said I still prefer using my trailer for even short trips as the bathroom is always in the same place, the bed is the same, I can eat when and what I want, when I had the dogs they always went with me.
It helped with the first wife as she was on Oxygen and I had to carry her concentrator and spare tanks. Add to that when she got tired I could just pull over and she could sleep.
  #33
Old 10-13-2017, 07:26 AM
dirthawg's Avatar
dirthawg dirthawg is offline
dirthawg is gaining momentum as a positive member of FTE.
When connecting an RV to shore power or a genset will the on-board converter/charger replenish a pair of batteries or even a single battery in a 10-12hr period?
Would connecting a quick charger directly to the batteries on the tongue without disconnecting them first cause any damage to the RV converter/charger or other wiring?
  #34
Old Today, 12:29 PM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Running a generator while overnighting at a Walmart will likely get you kicked out. More and more Walmarts and/or the townships they are located in are not allowing overnight parking. Look to see if there is a Cabelas or two on your route. Also, there are truck stops and highway rest areas with RV spots where you can plug in for the night. Every 2nd or 3rd night in a KOA is a real good idea.
  #35
Old Today, 02:21 PM
some of the national Chain Restaurants offer overnight parking for free..
a few even have marked off lanes just for RV's .. mostly in the rear of the building.. so away from road noise.
for self contained units only...
  #36
Old Today, 02:56 PM
JayTheCPA JayTheCPA is offline
JayTheCPA is gaining momentum as a positive member of FTE.
Quote:
Depends on how far down the batteries went and amperage of the charger.
Unless I am missing something, seeing as the battery bank should get a charge from the tow vehicle while traveling, the on-board charger should not have that much recovery to do.
  #37
Old Today, 04:25 PM
meborder's Avatar
meborder meborder is online now
meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.
The rate if charge from the tow vehicle depends on the difference in voltage between the TV and coach battery. As the charge on the coach is restored the rate of charge drops to almost nothing which is why they go dead after 2 or 3 days without being plugged in. They are just never getting s full charge from the TV.
This is why I suggested the DC-DC charger. It will maintain a full charge rate while driving and keep the charge up.
The 12v wire from the TV should be considered a charge maintainer, not a charger.
Today is the day........ Karl4Cat 6.7L Power Stroke Diesel 11794 Today 04:44 PM
F-350 configuration for truck camper RickJohnson 2017+ Super Duty 6 05-30-2017 07:24 PM
$8 buck oil change 17 Oaks 6.7L Power Stroke Diesel 23 03-01-2016 09:22 AM
Researching for a New Travel Trailer northwindone Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups 44 02-26-2016 03:13 PM
Wal Mart Fuel Discount 17 Oaks 6.7L Power Stroke Diesel 8 11-02-2015 02:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
