4x4 engine swap
4x4 engine swap
I was browsing the LMC catalog and came across this page for engine swap kits.
Truck Parts and Truck Accessories
It lists kits for 57-64 and doesn't note between fitting 2 or 4 wheel drive. Were the 2x and 4x trucks similar enough in that era that these kits would work on both? I'm also wondering if my 65 F100 4x with the older leaf spring front suspension is much different than the 57-64 trucks mentioned. Assuming these kits do work on 4x trucks that is.
1965 F100/250 4WD; 1965/66 F350; 1966 F250 4WD are similar to 1959/64 4WD, but some of the parts are not the same.
1965/66: Upper (upper) pic // 1964 (same as 1961/63): Lower pic (front only):
but I happen to know a guy
who could set you straight
if you're willing to wait
'cause he's seen many beers go bye
now he's gone
Where there is a will there is a way... I hadn’t heard of any bolt in options that work with the bellhousing mounts to frame I have.
4x4man514
23
07-19-2019 04:07 AM
bigd0785
12-11-2018 01:18 PM
Jamie4fam
03-09-2017 11:41 AM
drguitarum2005
08-30-2013 11:20 AM
AlaskanEx
08-01-2010 10:31 PM
