Is this important?
Ours have little clips that go on the ends of the pad and one that slips on to
help with rattle I think. But that clip does not belong on out trucks from everything I have seen.
At about 3:35 into the video you can see the clips on the old pads and right
after that he shows placing the new clips on the pads.
Here are the 2 types of hardware that I know of.
You have the first one with the extra long springs and
then the next one that is the same one I used the last
time I did the brakes. That little extra spring can be a How
does this go on? The first time you open a kit and have never
seen that type before.
NOT a Superduty brake part.
Originally Posted by krifenbu
I put rear brake pads on my 2004 Expedition this weekend and that clip looks like the one that is on the caliper. Funny you found a Ford part on the road.
Krifenbu, I just figured that it was a Mopar part that I kicked up on the road.
I would pull wheels and check just to make sure. How much trouble would it be to make sure?
Edit: Nevermind the above. I just looked and those are on the Expy. I knew I just recently seen them.
If your doing an Expy, an old pictorial from 100 years ago. That clip design was used by the caliper manufacturer on several manufacturer lines.
http://www.facebook.com/pg/TooManyTo...13745158706842
The lower clip was designed by a NVH engineer at our company (not the caliper manufacturer) who got a patent on it, and now he is a VP at MSC.
There are slightly different versions of it depending on the caliper size/application. The clips can be a pita if it’s not fully installed as it usually pops out on the road since it’s only retained by little nubs. Most of Eric’s patents are about noise insulators, the little shims attached to the back of the brake pads. At the OE level they take a lot of design and research and are very specific to vibration and in some cases at specific temperatures. He’s got a lot of patents.
mOROTBREATH
28
06-13-2011 08:50 AM
qwertmonkey
1999 to 2016 Super Duty
31
12-03-2010 02:38 PM
shark13
03-01-2007 04:35 PM
