Battery Question
Yes, direct swap no modifications necessary. I've put AGM in all my vehicles, oldest being an '84. Your '18, like my '19, does not have a battery monitoring system like the newer trucks. The manual just says to leave the truck undisturbed for at least 8 hours. I imagine you do that every evening anyway.
Here is a thread I made awhile back. Never did make any Forscan changes and do not believe it is necessary. As you will see, others have simply replaced with AGM's, nothing else, and had no problems. https://www.ford-trucks.com/forums/1677378-forscan-agm-battery-setting.html
