any help with determining curb weight - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 10-09-2017, 06:41 PM
j759ll j759ll is offline
j759ll is starting off with a positive reputation.
I would like to get some curb weights of trucks if you can, diesel and gas CCSB, CCLB, Lariat, KR Platinum. per ford see below, gas CCLB is 6989. I went on the scales with my Lariat Ultimate with B&W oem ford puck hitch 150# my wife and I combined 500# I am the heavy one 6'3" 350. also had 1/2 tank gas and the goose hitch attachments and the weight was 7860 - those will drop me to 7210. - 189 for gas 32 lbs over the curb. which gives me 4290 cargo. Fords numbers don't jive to me.
also the rear axle rating is 7230# and the tires supplied have payload rating of 3640 per tire which exceeds the rear axle rating 7280
Old 10-09-2017, 07:11 PM
cattaco cattaco is online now
cattaco is starting off with a positive reputation.
I believe curb weight includes a full tank of fuel.
Old 10-09-2017, 10:08 PM
mhoefer's Avatar
mhoefer mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
350 CC LB 6.7 diesel, lariat ultimate am right at 8,000 lbs with full 50 gallon tank and 205 lb driver. Only some minor tools in the under seat storage. My old 2005 CC SB diesel was 8780 lb with smaller fuel tank and me, same weight roughly. 800 lb difference, I have right at 3900 lb pay load max.
Old 10-10-2017, 06:05 AM
what is bugging me is the tire and loading sticker 3936 which is 500 lbs below the capacity of the truck which is 11500 minus curb weight 4440. Goodyear and Michelin have their tire rated at or above the axle rating so the tire is not the week point in the rating
Old 10-10-2017, 06:07 AM
Quote:
Thank You your weight seems to be on par with the curb weight listed for diesel CCLB 7739
Old 10-10-2017, 06:34 AM
SDcrewzer's Avatar
SDcrewzer SDcrewzer is offline
SDcrewzer is gaining momentum as a positive member of FTE.
Exclamation
Check the top of the GAWR column, and then see note "(3)" at the bottom of the original document page. The GAWR is based on the WR for the lowest-rated components (axle, tires, springs, wheels). I suspect the 7230 lbs. GAWR is based on the spring specs.
However, something is amiss here, as a pair of 18" or 20" wheels are rated at 2 x 3590 lbs. = 7180 lbs. See eSourcebook Specs page 61.
I believe the published curb weight specs include a full tank (industry norm) but are otherwise based on XL trim models with no options. You'll need to factor the weight of all options into your equation. See Note (2) on your sample Weight Rating page.
HTH,
Jim / crewzer
Old 10-10-2017, 06:41 AM
This may be a stupid question but shouldn't you be able to figure your curb weight by taking payload capacity minus your gvwr?
Old 10-10-2017, 07:01 AM
HTH,
Jim / crewzer
I have weighed my truck and the curb weight with my truck Lariat ultimate not lacking anything that would add any significant weight is very close to the weight on the list just not getting the sticker with 3936 losing 500 lbs of load
see tire specs
Old 10-10-2017, 07:03 AM
Quote:
yes I weighed my truck and it is very close to the number listed my problem is with the tire load sticker 3936 it is 500 lbs lower than the diff between 11500 and curb weight
Old 10-10-2017, 08:04 AM
Carbon8 Carbon8 is offline
Carbon8 is starting off with a positive reputation.
Quote:
What options do you have? Normally those published numbers are for base model trucks. Each truck has a specific payload depending on options and the payload sticker supersedes any other info.
Old 10-10-2017, 08:10 AM
Quote:
6.2l 4.30 CCLB lariat ultimate, camper pack plow pack LED lights 5th wheel prep goose neck kit sun roof spray in bed liner and the weight at scale minus approx gas in tank puts me at 32 lbs over listed curb
Old 10-10-2017, 08:29 AM
yelwinger yelwinger is offline
yelwinger is starting off with a positive reputation.
My 2015 lariat crew cab short box and 6.2 gas camper pak chrome pak with a Reese fifth wheel hitch in the bed and a full tank at the cat scales was 7840 pounds.
Old 10-10-2017, 08:34 AM
RainDesert's Avatar
RainDesert RainDesert is offline
RainDesert has a good reputation on FTE.RainDesert has a good reputation on FTE.RainDesert has a good reputation on FTE.
Old 10-10-2017, 08:45 AM
Quote:
7840? That seems really heavy for the 6.2. What does your payload sticker say?
Old 10-10-2017, 08:46 AM
SDcrewzer's Avatar
Exclamation
Using Ford's numbers, 11,500 GVWR less base XL 6.2 4x4 CCLB model curb weight (6989) = 4511 lbs max load capacity for a "stripped" truck with no upgrades or options. 4511 - 3936 = 575 lbs. "missing" load capacity.
I suspect your 2017 truck's following upgrades and options add up to something close to 575 lbs.:
  • Lariat trim upgrades
  • Lariat ultimate trim option {incl. tailgate step (~38 lbs.?) and the glass moonroof}
  • Chrome Package (includes 2x outside running boards)
  • Gooseneck hitch kit
  • Snowplow / camper package
HTH,
Jim / crewzer
reference:
What's yer payload 82_F100_300Six 6.2L V8 49 10-14-2017 09:45 AM
First tow CCSB 350, hit the scales. RedRocketFx4 2017+ Super Duty 23 10-10-2017 09:10 AM
Lowered F150 turned out to be my best tow rig by far ..pics Go-on3 2015+ F150 13 09-07-2017 07:07 AM
2014 F-250 XLT 4WD CCSB 6.2 4.30's + TrueTrac defekticon Vehicles for Sale 0 05-12-2017 11:58 AM
Top Towing Myths Solved! Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-17-2017 01:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
