up-pipe coating? and a few other questions - Page 2 - Ford Truck Enthusiasts Forums
Old 10-09-2017, 03:59 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
Quote:
Originally Posted by andym View Post
Southerners.
This is what a truck looks like after ~10 years of driving on salted roads in the winter (notice the door was replaced, probably because the rot got too bad):
They use salt because it lowers the freezing point of water so ice doesn't form on the roads as easily. It's usually mixed with cinders, gravel, or some other kind of traction aid as well.
NAILED IT!
Old 10-09-2017, 05:45 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
OK. I get it! I was not thinking about the "external corrosion factor" as being John's only justification for coating/wrapping the up-pipes. It's just not something I ever consider except when buying a used vehicle (for me, only salt-free vehicles are ever considered).
Old 10-09-2017, 06:27 PM
Sous's Avatar
Sous Sous is offline
Sous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud of
I bought a salt free truck and last year (truck was 17 years old) when I replaced the OEM exhaust, the bolts popped loose without issue. I will never own another salt plagued vehicle again after living in the mid-west for a while. Ever...
Concerning the up-pipes, I say pass on the coating. In my opinion unless you were pulling some serious HP numbers, you are not going to notice a bit of difference.
Old 10-09-2017, 07:00 PM
SaintITC SaintITC is online now
SaintITC has a very good reputation on FTE.SaintITC has a very good reputation on FTE.SaintITC has a very good reputation on FTE.SaintITC has a very good reputation on FTE.
Is there any thought about a wrap reducing engine noise?
Old 10-09-2017, 07:08 PM
z31freakify's Avatar
z31freakify z31freakify is offline
z31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to all
Heat wrap them, you will get less heat on the firewall.
Old 10-09-2017, 09:25 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
When you live in the rust belt, finding rust-free vehicles from the south is a real treat. It really is a whole different perspective on car shopping. Back when I joined FTE in 2002 and lived in Buffalo NY, I'd just bought a 1990 F-150 from a small dealership that specialized in shipping rust-free cars and trucks from the south. I had the most rust-free, 12 year old truck truck in WNY for one year.
Quote:
Me either! I can't stand dealing with rusted fasteners rotted out bodies, frames, and spring hangers. I knew of one guy whose frame was rusted clean through and his truck was held together with a chain binder.
I agree with this. It's an extra 1% of power which is worth it if that's what you need out of your motor. The vast majority of us don't.
Quote:
What problems result from the heat of unwrapped pipes on the firewall? My up pipes aren't wrapped and my firewall doesn't seem to be melting or catching on fire.
Old 10-10-2017, 06:12 AM
Walleye Hunter Walleye Hunter is offline
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
Old 10-10-2017, 02:23 PM
Less cabin heat from the fire wall, stick your hand there and youll feel it
Old 10-10-2017, 04:02 PM
andym's Avatar
Again what problems does this cause?
Old 10-12-2017, 05:24 PM
ff lc freak's Avatar
ff lc freak ff lc freak is offline
ff lc freak is starting off with a positive reputation.
I got a box of goodies in the mail from Riff Raff today!
Now I just need to find some time to install all of it. I'll take pics when I'm done.
Old 10-12-2017, 07:12 PM
Sous's Avatar
It will feel like a completely different truck with the new parts on there if the old ones are worn and/or leaking. Keep us posted on the progress and enjoy working on it.
Old 10-12-2017, 08:04 PM
mjtpolice76 mjtpolice76 is offline
mjtpolice76 is starting off with a positive reputation.
I wrapped mine didn’t cost much
  #28
Old 10-12-2017, 11:26 PM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
Nice job! Looks like they came that way.
  #29
Old 10-13-2017, 12:06 AM
I smell a rat! These can't be the same up-pipes, look at where the bellows are.
Edit: I'm an idiot. Thought it was the same guy posting. Clearly one of these is an e99 or maybe an OBS. I forget what my e99 up-pipes look like..
  #30
Old 10-13-2017, 12:23 AM
Stebs Stebs is offline
Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.
One thing that hasn't been mentioned about the hpop lines... you will most likely want to either reseal the old fittings with new orings or just do what I did and replace the fittings....
Fixing Leaks, what else should I do? JGRNAUT_7.3L 1999 - 2003 7.3L Power Stroke Diesel 10 11-15-2017 12:59 PM
A Newbies Reflection, Thank You, and Replace/Reseal Thread: HPOP, UpPipes, Fuel Bowl, Turbo BdgrDuckHntr 1999 - 2003 7.3L Power Stroke Diesel 23 07-03-2017 09:48 AM
The Up(pipes), Down(pipes) and Out(exhaust) of my refresh ZachinCO 1999 - 2003 7.3L Power Stroke Diesel 16 11-23-2016 02:10 PM
Joined the club... Up pipes (added photos) scootermcgavin 1999 - 2003 7.3L Power Stroke Diesel 13 10-15-2016 12:17 PM
Installed all new CAC boots and now the truck runs horrible? ? jstihl 1999 - 2003 7.3L Power Stroke Diesel 318 03-25-2016 10:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
