2003 4.6 cyl head warpage specs
I have posted below that I am getting water in oil after head install and suspect warped head. Wondering what the flatness spec is? Is there a machine max spec and a discard max spec? Are these modular heads even able to be machined?
Also how much is allowable to mill off the heads to correct warp?
http://www.alldatadiy.com/alldatadiy...1616/120956626
Use a straightedge that is calibrated by the manufacturer to be flat with 0.0002 inches (0.005 mm) per running foot length. For example, the straightedge may be 24 inches (61 cm) long. That means the machined edge must be flat within 0.0004 inches (0.010 mm) from end to end.
Depressions or marks measured to be over 0.001 inch deep will not seal properly. The overall flatness check (head end to other end) is not as critical.
dieselaholic
08-21-2008 07:45 PM
scottie2hottie
11-25-2004 11:11 PM
