Lifting my 6.2 please help
#31
Originally Posted by DSLTRK60
Are lifted trucks less useful?
I guess it would depend of how the truck is used.
I'm a contractor, that gets in and out of the bed 20+ times a day. Lifted => less useful
Fuel economy is important to me, it takes less energy to move a stock truck. Lifted=> less useful
I don't rock crawl, so the clearance isn't too important. Lifted=> more useful
I like suspension components to last as long as possible. Lifted=> less useful
I like tires that wear longer and are cheaper to buy. Lifted=> less useful
I also agree with the mechanical engineer, a higher center of gravity isn't as stable as stock. You can come back to prove me wrong after you perform the moose test and compare.
I do like lifted trucks that may have a 2" lift and moderately size tires.
It doesn't take a mechanical engineer to know that a higher center of gravity makes a vehicle more top heavy. I'm not disputing that. If you lift, then run stock wheels, it's going to be more top heavy. Better than stock coil springs and shocks can improve this, and can actually make it ride better, with less lean in the turns. But if you space your wheels out with offset and a wider wheel, you counter act that higher center of gravity.
Here an explorer with stock wheels
Here's an explorer with wheel spacers, no different than offset on wheels
I don't need to go to school for 4 years to understand this. Surely to god there are others out there that understand this and agree.
#32
I agree with a lot of what you said. If I was a construction contractor(which I was in the past), I would be driving a long bed stock height pick up, with step bars running all the way to the rear tires, or a van. I would also have more concern with fuel mileage, tire mileage and
suspension wear. But since my daily commute is 9 miles one way, I don't give a $#+. I still have no problem running to the Home Depot and picking up a load of lumber and/or plywood for home projects or side jobs. Maybe if I was 5' 4" it would be hard, but I'm 6' 4", so it makes some things easier. My step bars are about the same height as my door seals were stock. So considering I didn't have step bars, it's no different.
https://youtu.be/y_52oGEU5XA
#33
True, the 17s have even better clearance. A front locker will get you a lot farther than a 5 inch lift on a jeep trail.
These trucks are long, and the longer the vehicle, the more purpose a lift serves off road.
You guys also need to remember, the 17's are substantially taller than the older generation. I guess they don't tow as well.
#34
Can you please elaborate on how 17's have more clearance? I'll agree with the front locker, if it's air/electric. I wouldn't have a full time front locker on a vehicle I had to drive on the street. That's personal preference.
#35
#36
#37
Originally Posted by 82_F100_300Six
I never realized how much money adds up when you get a lift, wheels and tires wow
#41
Considering that a 2017 is made of aluminum and the farme and drivetrain is so beefy, I believe a large majority of weight is below the frame. My last SD was a 2001. My current 17 has a whole lot more clearance under the truck. What all this means I have no idea however lifting a new AlumaDuty should be much more stable than lifting an older model. More weight down low and less up top
#42
But I do have to ask what this has to do with my quote?
93f250tn
19
11-05-2010 11:44 AM
cpereira
02-15-2003 04:54 PM
