What is This Parts Name - Ford Truck Enthusiasts Forums
Old 10-08-2017, 06:28 PM
coopster17 coopster17 is offline
coopster17 is starting off with a positive reputation.
What is the name of this part in the photo that is holding the bolt to the passenger side inner fender. The bolt holds three wires. I would bet it is no longer available. Can anyone tell me if they had to fabricate something?
This fits a 1965 Ford F100, 352 engine;
Old 10-08-2017, 06:39 PM
53deere's Avatar
53deere 53deere is offline
53deere is starting off with a positive reputation.
Junction block, terminal block.
If you don't care about original look, something like this....https://www.delcity.net/store/Stud!T...SABEgLu7vD_BwE
Old 10-08-2017, 07:00 PM
Thank You Sir.
Much appreciated.
Thanks for the lead on obtaining the Junction Block / Terminal Block also
Old 10-08-2017, 07:31 PM
mrpotatohead mrpotatohead is offline
mrpotatohead is starting off with a positive reputation.
Lots of different cars had something similar. Chevy pickups had them on the firewall.
Old 10-10-2017, 07:59 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon is a name known to allspurredon is a name known to allspurredon is a name known to allspurredon is a name known to allspurredon is a name known to allspurredon is a name known to all
I have made them from a strip of plexiglass, lexan if you have it.
Old 10-11-2017, 09:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
D3TZ-14448-A (replaced C7TZ-14448-A) .. Junction Block - 1 stud - 1/4" -20 / Obsolete
1965/67 F100/350 and etc.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 71 = 800-476-9653.
Old 10-11-2017, 03:38 PM
Thank you Number Dummy.
One more question;
I am confused, is this junction box suppose to be a metal ground or not?
Old 10-12-2017, 10:33 AM
TA455HO's Avatar
TA455HO TA455HO is online now
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
Not a grounding block. In fact if the junction block fails or falls apart enough to allow those wires or the common stud they bolt to to touch ground - i.e. the metal inner fender that’s holding it in place - it is sure to release the smoke from the wires really fast and can go downhill from there quickly - up to and including burning the whole truck to the ground. Caution is in order.
Chad
Old 10-12-2017, 04:31 PM
Thanks for the Info Chad.
Really good to know.
I was looking at a homemade metal junction block and that would have been a disaster.
Appreciate it very much!!!!
Old 10-13-2017, 06:50 AM
matthewq4b matthewq4b is offline
matthewq4b has a very good reputation on FTE.matthewq4b has a very good reputation on FTE.matthewq4b has a very good reputation on FTE.matthewq4b has a very good reputation on FTE.
55 F100/5.0 EFI build SVT-F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 85 09-12-2017 01:09 AM
vacuum reservoir/canister bolt koll 1999 to 2016 Super Duty 5 04-05-2017 09:49 AM
Need some info TacoSplitter 6.0L Power Stroke Diesel 4 10-16-2016 08:17 PM
460 EFI Conversion 1978Quinn 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-14-2016 10:15 AM
Ignition Lock Cylinder Washer akg123 1987 - 1996 F150 & Larger F-Series Trucks 3 12-17-2015 01:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
