The charcoal canister should yes it has a check valve to hold the vacuum you would have to block the ports and vacuum down the check valve is like a flap basically lets it vacuum out but stops pressure I think right at the fitting. Not sure on the Booster but I would guess yeah it should hold some sort of a vacuum.
Pumping through just the valve from opposite direction, there is enough of a restriction that the gauge will at least lift its needle for a moment while actively pumping.
Pumping rapidly on the booster moves the needle not at all.
After replacing booster check valve for certainty, I should be able to pull & hold vacuum with a Mitty vac tool, correct?
Other than ruptured diaphragm, leaking perimeter seal, etc inside booster has leak, right?
Meaning its booster time.
nspect the Check Valve
Disconnect the vacuum hose where it connects to the intake manifold. Do not disconnect the vacuum line from the booster. Air should not flow when pressure is applied, but should flow when suction is applied. If air flows in both directions or there is no air flow, the valve needs to be replaced.
Mitty vac alone will not pull enough vac to test booster.
Using another household pump, I pre-loaded booster & used the mitty to gauge & boost up, but got no hold.
Used same procedure to check replacement booster which held vac.
Wait till you get ready to rep a brake booster.
Choices are extremely limited.
Purge solenoids are very pricey & too much to rep on a whim & so the TB nipple is for now capped.
Since no one can tell me anything definitive (and I can't find anything) on the state of the solenoid (NO/NC, energized/non-energized, etc) I'll drag the mitty to the JY & do some tests.
Results are good, stumble/slight miss at 60-65 & 70-75 is gone.
The above post and image is in the un-powered state.
My guess is the it would be open in both directions.
I would go back to the bench an check the powered state but I am running out of time right now and need to get going. Maybe I will check it out tonight.
