Buying a 1990 Ford Bronco
I'm looking to possibly buy a 1990 Bronco with relatively low miles (125k). The body seems to be in good shape with little rust shown. It has the 351 with an E4OD trans. What are some known issues that I should look at before buying? I've heard the first years of this trans could be an issue. Thanks in advance!
At the very least get a good look and sniff of the transmission fluid while it's running. If it's brown or burnt, then I'd walk away. Also if you suspect anything shady, be wary of fluid that's brand new as it's easy to get a transmission to stop slipping for a few hundred miles with nothing more than a fluid change. If you can get it to a shop to get it inspected (which is a VERY GOOD idea) make sure they drop the transmission pan and see what kind of surprises are hiding in it.
If it's been well maintained there is no reason to shy away from it though.
granny_rocket
05-10-2015 04:49 PM
laverne
1978 - 1996 Big Bronco
11-17-2003 11:16 PM
