Need a Guess at Hitch Capacity
This trailer hitch is on a 1986 F-350 dually at the wrecking yard. It is well made and available for $35 if I pull it. The label is long gone so I don't know what the towing rating is.
I am hoping someone recognizes it and can tell me the towing capacity is.
Thank You
Thank You
I like the extra thick grade 8 washers.
Would you recommend lock washers, nylock nuts or thread locker.
Received 6,622 Likes
on
on
The factory used blue thread locker on the Excursion hitch bolts for sure, probably the same on the SD pickups.
My new Torklift SuperHitch 20K that has a 2000lb tongue weight rating used Grade 8 hardware with lock washers and standard nuts that were torqued to 80 ft/lbs.
First off, what a BEAUTIFUL EX! In a 'previous life' I had a '05 EB EX, 4X4 6.0 PSD as a company truck...man, I loved that truck!
All,
I'm in agreement for clean, yellow zinc plating/coated, Grade 8 bolts with a Grade 8 flat washer,one at bolt head and one at nut end, with Grade 8 spring-lock or split-locking washers and standard nuts. Blue thread locker is optional, but not required. Red loctite may require heat to remove. To assist in the corrosion-resistance, twice a year I use a hand sprayer to dampen the hitch connectors with diesel oil (fuel oil); to keep the rust to a minimum..... It works for me - 'your mileage may vary'.
BarnieTrk
