460 VIN number location
Casting codes are on the sides of the block, the date code is in the lifter gallery, see picture in post 3:
where is the serial number- 460ci? - Ford Forums - Mustang Forum, Ford Trucks, Ford Focus and Ford Cars
OK those numbers may be part of the VIN but won't tell you what you want to know.
The date code in the valley tells you when the block was cast.
The casting codes on the sides of the block tell you what revision and earliest possible date the block was used. Later revisions were used for several model years if not all the way through the end of production.
Other than the general curiosity, what is it you are trying to figure out via the date of the engine? Since it is a transplant, several things could have changed vs. the OEM configuration. That is part of the joy of owning an older vehicle with a transplant.
This will also help me with what parts I will need for it the casting code on the side of the block is D1VE-A2B.
Casting codes here. Note multiple pages, cylinder head info and a "how to read" section as well.
Kelly hotrod - Ford Engines Page 2
As far as parts, you will probably have to just make careful note of what you take off and replace it with the identical item. That block was used in several production years.
1971/73 Ford/Merc Passenger Car 429 / 1971/78 Lincoln/Continental Marks 460 / 1972/76 Thunderbird 460 / 1973/78 F100/350 460 / 1975/78 E250/350 460 / Some 1979 F150/350 & E250/350 460.
No 460's in F100's after 1976, no 460's in cars after 1978.
Casey Hope
15
10-07-2017 12:18 PM
lvin4jc
20
12-10-2011 09:01 AM
scrapy
03-18-2008 03:45 PM
