top tier diesel
Received 6,677 Likes
on
Apparently Top Tier for diesel has nothing to do with cetane, which is around 40 for the US versus 51+ for Europe. It does have to do with stability, lubricity, water content and particulate count.
It doesn't matter if it is delivered by the same truck as the place down the street as long as the Top Tier additives are added in the prescribed amount.
Relative to the ASTM D975 and D7467 specifications for diesel and biodiesel blended fuel in the U.S., the TOP TIER™ Diesel Performance Standard requires detergents to reduce deposits on the fuel injectors (both internal and external), improve lubricity (less wear on injectors and in the engine), improve fuel stability (less deposits in the fuel system components), and provide more protection against water and particulates that may be in the fuel before you dispense it into your vehicle or equipment.
So I took the bait. Let me get on the Internet and poke around at that "top tier diesel" claim. So I find the list - Licensed Brands | Top Tier Gas. One would think there there would be a list for Gas and a list for Diesel. There is no separation - in fact there's nothing but a blurb on what Top Tier Diesel is and everything else is about Top Tier Gas.
I think there is certainly an argument on Unleaded type fuel as to some being better or worse based on additives. Again in most cases the fuel is all coming from the same place so the only real difference is made when it goes into the tanker hauling the fuel, that's often where the additives (cleaners and other magical BS) are inserted.
When it comes to D though, it's really just more about how clean it is, and how often it is turned over. Even the absolute best D will turn to junk in time if it is sitting in a tank that doesn't see a lot of use, or they do not have a good water separation process before it gets pumped into your tank.
On that note, I would say yes Costco does have great Diesel fuel, but really that's only because it doesn't have time to sit in the ground for very long, and like most places, they run it through a filter from the ground to the pump. Where I get leery of some stations is in more urban areas or where there is only one pump in the entire station that even has D. If it's not a fuel they sell a lot of, you may be pumping something that has been sitting for a while, or they do not put as much effort into keep in clean before you finally get to use it.
In that case "Top Tier" really just means "new and clean."
From what I understand there is a difference in gasoline with the additives added to the gas
With these combinations of additives added to the gas gets a Top Tier approval.
This being said this would be the same for diesel fuel.
So buying diesel fuel with this label you would get fuel that meets Top Tier specification.
I would buy this fuel if it was in my area and I hope it comes to West Michigan.
You may want to read into and have a better understanding how the energy sector works.
Basically, all fuel, name brand or otherwise, all comes from the same refinery holding tanks of respective grade. since delivery is an added fee, retailer usually buy it from the closest location of a delivery radius.
Another word, Shell, Exxon, BP, Costco, Loves, Casey, Flying J, 7-11 etc, all come from the same tank. The only difference being the additive under the name brand, usually market under the trademark (Detergent formula, Fuel saver, Knock eliminator or whatever), which are all just a strategies to hype up the value for the added benefits and lead the consumers to believe it's a better product, thus welling to pay more. Since these added agent is not regulated, adding even just 1oz of additive in a 5000gal delivery, its not misleading but usually no measurable benefit can be detected.
Received 1,447 Likes
on
Top Tier is register trademark of Costco, call it whatever....God's Diesel if you will.
Howes Diesel Treat offer the same property enhancement, including removing water. That's what I use, it cost $13 for a 64oz bottle that treats 320 gal, that's $.04 premium to a gal. I add that at each fill up, thus I know its in the fuel I burn.
#28
on
The TOP TIER™ Diesel Fuel program is currently sponsored and overseen by General Motors, Volkswagen, Daimler Truck, Navistar and Ford
#29
Top Tier is not registered to Costco. Top Tier is sponsored by auto makers.
https://www.toptiergas.com/about-top-tier/#sponsors
The following users liked this post:
