Supplier for Leaf Springs
I just came in from crawling around under the truck, and from what I can see, dear old Dad took more than a few springs out of her. I could only count 8, and what looked like 2 springs worth of spacers on top of the stack under the U-bolts.
It is no wonder the truck sits level, and not raised in the rear like most.
I get the new springs, it may indeed prove to be too rough of a ride. If it does, I will probably do as you, and remove a few. Will see when I get the new springs.
The spacers were because the u bolts were not threaded far enough, so he put in spacers to take up the slack. I destoyed one set of u bolts getting mine off, so I ordered a new set. However, on the other side I had to run a die a considerabe distance up the u bolt so I could get em tight
. In hindsight, it would be more prudent just to oreder new u bolts all around!
those shock mounts i said were on their way, well they got here, they are for a narrower
spring, this 51 M3 with 18 leafs i think is 2.5" wide.
It has a spacer between the "normal" spring assembly, and the 4 leaf "helper"assembly, perhaps a inch ,maybe 3/4", i noted that I would need new U-bolts,these are quite long and they are formed on the "U" ,stamped/forged like, I am torn between wanting her to be a brute with a dump and wanting her to ride smooth on these backroads here, I ain't there yet so I have time to ponder, thanks for the chat!
so ,I have a set of probably lighter shock mounts for our trucks, not sure of year the seller claimed, i will check and get back.
I think I am started to fall in love with this truck.
Greg
Greg
acl9865
03-04-2018 08:33 AM
F-1
01-04-2016 10:46 AM
hotrod48
46
03-03-2006 08:29 PM
