EFI to Carb - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
EFI to Carb
Old 10-04-2017, 05:51 PM
studlybilly studlybilly is offline
studlybilly is starting off with a positive reputation.
EFI to Carb
Picked up a '89 Bronco that I'm doing a long travel setup with. Previous owner did a good job restoring, but chased a gremlin with the engine for a while. It stumbles during idle a lot and dies, does ok when revved up. They replaced almost everything except fuel regulator and fuel pump(s). Long term goal of this rig is to be on dual fuel with propane, so I'd rather switch to a carb setup for a simpler dual fuel. I have a 302 edel carb intake and some holley carbs, can I simply switch the intakes and leave everything else alone? I can figure out a way to sheet metal an upper plenum for what I want, but I'd rather be disabling a fuel pump than a complete EFI system when I switch back and forth
Old 10-05-2017, 12:50 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
depends on what transmission you have. I assume the bronco has a 5.0 in it?
pull codes and see what you come up with. some people just throw parts at a problem with out proper diag. I bet we could help you get this running correctly.
EFI to Carbeurator How Hard & Benefits? Building_Fords 1987 - 1996 F150 & Larger F-Series Trucks 122 11-05-2017 01:29 PM
stock 302 + Nitrous? Shadow944795 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 1 07-13-2017 08:59 PM
Need 240/300 4bbl Intake Inline66 Ford Inline Six, 200, 250, 4.9L / 300 7 04-16-2017 12:37 AM
To Much FUEL Pressure Gibby55 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 03-16-2017 11:07 PM
CHANGING EFI SYS 5X5 1987 - 1996 F150 & Larger F-Series Trucks 5 05-14-2016 03:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
