Exhaust manifold - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Exhaust manifold
Old 10-02-2017, 08:43 PM
rspitzer81 rspitzer81 is offline
rspitzer81 is starting off with a positive reputation.
Exhaust manifold
Can you put the exhaust manifolds from a late 80's - early 90's 5.0 Mustang, onto the 5.0 of the Bronco?
Old 10-02-2017, 11:34 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
They will bolt to the engine no problem but they will not connect to the stock truck exhaust.
Old 10-03-2017, 12:53 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
if your hunting for stock exhaust manifolds you would be better off just spending the money on some shorty headers. stock manifolds will crack and fail eventually.
Best way to lift 5.0 no exhaust manifolds Midnite1987 1987 - 1996 F150 & Larger F-Series Trucks 2 10-22-2017 12:40 AM
Intake manifold ?'s 56f1000 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-15-2017 02:09 PM
1993 F150 Exhaust Manifolds - Gaskets? jeff9942 1987 - 1996 F150 & Larger F-Series Trucks 18 09-27-2016 07:51 PM
Engine swap 93 F-150 SquareBody-F150-93 1987 - 1996 F150 & Larger F-Series Trucks 1 09-01-2016 05:36 AM
5.0 exhaust manifold to flange hardware assemly Troyus 1987 - 1996 F150 & Larger F-Series Trucks 4 04-11-2016 12:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
