Low power, stumble on acceleration - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 10-01-2017, 05:27 PM
1990Bronco4.9
1990Bronco4.9 is offline
1990Bronco4.9 is starting off with a positive reputation.
Hi all, I'm new here, hoping for help with my 1990 full size Bronco with the 4.9 six. It's weak under acceleration. It bucks if I floor it. It'll crawl along at low rpms up anything in low range. New distributor, cap, plug wires, plugs, intake manifold, exhaust manifold (was cracked) throttle position sensor, egr valve, pcm. The thing feels like the timing is retarded. It feels just like my old slant six when I'd forget to hook up the vacuum advance hose. It runs smooth at idle and low rpm/power settings, but stumbles when I try to accelerate, and bucks violently (sometimes) when I floor it. I have a timing light. Can one of you please tell me how to find the SPOUT connector? I have read that I must disconnect it before checking the timing, and I can't find it. Thanks and best regards,
Noah
Old 10-02-2017, 10:45 AM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The spout plug is in the wiring harness attached to the distributor.
Sounds like the motor is running excessively lean, are you getting any codes?
Old 10-02-2017, 03:21 PM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
This might help you locate the SPOUT connector:
Or you may have the older style in-line plug similar to this:
dmaxalliTech
04-26-2012 10:10 AM
the deno
1999 to 2016 Super Duty
01-12-2005 08:23 AM
Brownbear13
1997 - 2003 F150
13
11-09-2004 10:42 AM
sscaro
09-07-2002 02:46 PM
Quick Reply: Low power, stumble on acceleration
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
