steering columns
Old Sep 29, 2017 | 10:49 AM
joey7478's Avatar
joey7478
steering columns
change transmissions from c6 to aod whats the different in the steering columns? I have a 1990 e150. Thanks joey!
Old Sep 30, 2017 | 04:33 AM
wiskeyVI's Avatar
wiskeyVI
I'm not sure whats different in the column, but the linkage may be different?
Old Sep 30, 2017 | 07:05 PM
Wildman25's Avatar
Wildman25
Are you having shifting problems?? Like it does not shift out of first?
I know the AOD tranny takes a TV cable, and I don't think the C6 used the cable. The other problem might be the TV cable adjustment.
Check this - Ford AOD Transmission
Old Oct 1, 2017 | 11:38 AM
joey7478's Avatar
joey7478
I'm not having problems ,just putting in a engine and tranny that was in another van and it had an aod and was told stering columns might be different.
Old Oct 1, 2017 | 01:40 PM
annaleigh's Avatar
annaleigh
From the truck thread i found this:
The AOD and 3 speed columns are the same. What is different is the connecting rod between the column and the transmission shift lever. They not only vary by transimession type, but also 2wd/4wd. Also, the shift indicator is adjusted by tightening or slacking the nylon adjuster on the indicator cable...loosen the 8m nut that holds the retainer to the column and slide it up or down until the indicator reads where you want.
And then:
AOD and 3 speed columns are NOT the same. The "detents" aren't exactly the same and have a different spread. You can still work with such a swap but it's annoying. The detents are the notches you feel when you put the truck into various gears. The transmission has a set and so does the column, they need to match.
I put an AOD into my C5 truck. I've adjusted all sorts of different ways but the shift indicator never will read exactly right. More importantly I can choose to adjust to where I can put the truck into Park or into 1. But not both. If you put a C6/C5 column into your AOD truck expect the same problems. Realistically I never use 1 so I can live with this but it's still annoying.
https://www.ford-trucks.com/forums/7...ng-column.html
Old Oct 2, 2017 | 06:51 AM
Wildman25's Avatar
Wildman25
annaleigh solved your problem, as the AOD did not have the overdrive switch, and the shifting pattern are on the column, as in the topics she posted.
Old Oct 14, 2017 | 12:05 PM
joey7478's Avatar
joey7478
steering columns
has anyone replaced steering columns from a different car or truck in a 1990 e150 van? Thanks joey!
reed1951
Jan 2, 2014 05:50 PM
Holehawgg
Mar 25, 2013 08:37 AM
gov2mod
1978 - 1996 Big Bronco
Sep 26, 2005 12:11 AM
ty
Jul 27, 2003 08:59 PM
gonefishin
Mar 14, 2003 09:03 PM
