K&N air flow system
K&N air flow system
i just put one on my 2001 4x4 5.4 and no you dont have to change your maf your maf is good up to roughfully 600 horsepower and your kit includes everything you need i like mine alot and its a easy mod to put it on your self if you can read directions then you could put it on rite back and tell me what you think thanks damon
K&N air flow system
Really? My 88 5.0 Stang has 156,000 miles on it. I installed the K&N filter and a home made ram-air scoop uner the front bumper @9,000 miles. My Mass-air meter is as clean as the day I bought it and it still runs 12.40's in the 1/4 mile. The motor has never been apart and is all stock except for the spacer between the upper and lower intakes, MAC nickle plated headers, off-road 2 1/2" pipes and 2 chambered flowmasters with 3.55 gears, and a 75hp shot of NOS.
They must filter pretty good or the dirt would have worn out my engine by now!!
Jimmy
Jimmy
K&N air flow system
I have had cigarette buts, leaves and everything else sucked up into the filter housing because the air intake is only about an inch off of the ground. Alot of road dust and dirt as well. The oil on the filter actually catches smaller particles of dirt than a paper filter.
Jimmy
Jimmy
K&N air flow system
The biggest benefit to installing an aftermarket air filter system is the whole it leaves in your pocket!
I believe the Ford engineers have the air filtration system designed pretty well. Don't you think that Ford would use this oil on a sponge technology, if it in fact would increase power and gas mileage, and still adequately clean the incoming air ?
Save your money. Just my .02.
K&N air flow system
I agree that they've designed it to work with their designs however, they also have financial considerations. Think of all of the aftermarket add-ons...they take a current design and maximize its performance.
Re: hole in the wallet
"The biggest benefit to installing an aftermarket air filter system is the whole it leaves in your pocket!
I believe the Ford engineers have the air filtration system designed pretty well. Don't you think that Ford would use this oil on a sponge technology, if it in fact would increase power and gas mileage, and still adequately clean the incoming air ?"
Corporations big and small don't always do things that make sense. I have no doubt that the oil companies and the automakers have "agreements"
I think we would have seen cars and trucks with drastically better fuel economy if the automakers were serious about letting the technology out.
The oil companies have a lot to lose if trucks get any better gas mileage than what the government tells them (automakers) they HAVE to design vehicles to get.
there is what is right and then there is reality
I have a 2001 F-150 Supercrew 5.4L, 4X4. I live on a dirt road and go offroad quite a bit. I was considering installing the K&N System but I wanted the opinion of others. Since I do live on a dirt road and got offroad often, will it cause more problems than it's worth because of more dust and dirt getting into the motor?
I think it will work fine
"I have a 2001 F-150 Supercrew 5.4L, 4X4. I live on a dirt road and go offroad quite a bit. I was considering installing the K&N System but I wanted the opinion of others. Since I do live on a dirt road and got offroad often, will it cause more problems than it's worth because of more dust and dirt getting into the motor?"
I've read about others' concerns regarding dust getting through the folter because they could see light through the K&N filter while they could not see light thru a paper filter. I put a KN filter in my wheelchair van (E350) last week and I can notice a difference in power. Granted, I had NEVER changed the paper filter since we bought the van, but we have not driven it much due to the gas mileage. So, it may have been that the paper filter was that dirty and a new filter made a diff (regardless of WHAT brand filter), but then again, maybe the KN made a diff.
Anyway, my opinion is that the K&N filter will filter BETTER than the paper due to the oils soaked into the cotton gauze. The paper filter relies on the tightness of the paper to keep dirt out and let air in. Thats why you can see a bit of light thru the paper, but you can darn near see through the K&N. The tacky oil in the K&N (I believe) will stop way more dirt, much more efficiently than a paper filter, and with less air restriction - even as the filter gets dirty.
I didnt buy a whole intake kit. I just bought the filter for $43 and put it into the stock airbox. fit like a glove. saved me hundreds over installing a whole kit.
Anyway, thats just my opinion based on logic and physics. Others may see things differently
Doug
Doug
