Timing/Spout Connector Issue 88 F250 460 EFI
#107
That's what I'm debating on doing as well, I would just like to have a permanent gauge in the engine bay. Do you know if the Schrader valves are the same size between the 5.0L and the 7.5L? That gauge kit is for the 5.0L but I believe someone said in a forum somewhere that it would fit the 460 as well
#108
I'm guessing that off the assembly line, there was a matching/corresponding wire on the interior side of the plug.
It may be too big of a job to fix that, so you could tap into the wire that; “gets lost into the dash somewhere“ , and run it out to the wire on the outside plug.
#109
Nice drawing, looks better than mine....
One of my concerns is that you may blow the #5 - 15 amp fuse by adding the load of the O2 Heater.
I believe the voltage flow is from the Battery to the Ignition Switch, back out, then spits off to the Fuse Box & O2 Heater. So, fuse #5 normally does not see the load of the O2 Heater. Now it does…….
So, keep an eye on Fuse #5, I think it powers Turn Signals & Back-up Lights.
I would change the 30 amp fuse for a 10 amp, this will protect the 15 amp and it’s circuits.
#110
Thank you, that was a final draft for show purposes haha
That's a good idea about throwing in the 10 amp in place of the 30. I'll do that tomorrow when I replace some vacuum lines, sprk plug wires, cap and rotor button. I'm hoping this will finally correct the stumbling/sputtering issues, I've already cleared the afternoon so I have nothing to bother me. I will keep the post up to date. Thanks vjsimone, you've been a great help with this
#111
Timing not right? I figured it was. When setting the timing to 10 degrees and plugging the spout in, the timing advances to 30 degrees (the manual that came with my code reader said it should do this). I figured that's why the guy I bought the truck from had the timing set to 30 degrees without the spout connector plugged in. Does that not make sense?
#112
#114
#115
Okay yes that makes sense to me, I was just confused on if you meant there was another issue in regards to the timing. Now that I have the truck drivable with the spout in, its noticeable how much easier and smoother it runs through the rpms now
#116
Does anyone happen to know the sizes of the vacuum lines? I used a set of calipers and measured the ID of a couple lines but the calipers were giving me too tight of tolerances and was reading down to 1/128" so I would have to either round up or down. I've ordered 5 feet of both 3/8" line and 5/16" line to see how the fitment goes but it'd be great if I could get the correct sizes and order the rest of the lines at one time
#117
#119
From my understanding, if it had a vacuum leak i would be adding more air to the fuel mixture causing it to starve for fuel under load/acceleration. That would mean this "pop" could be caused when i let off of the throttle relieving vacuum pressure and in turn richening the fuel ratio temporarily, causing unburnt fuel to make in to the exhaust and combust. Am I on the right thought path here?
Yes still getting a fluctuating idle which would make even more sense of a vacuum leak, correct? I planned on performing the idle adjustment procedure you showed me after i install the new vacuum lines, plug wires, cap and rotor button (as long as I don't find more issues).
I dont think that would be a bad idea either, thank you
