Timing/Spout Connector Issue 88 F250 460 EFI
#91
#92
So, that Gy/Y wire from the O2 sensor may go to one of those F-Links under the Dash (F-Link "X", Blue, 20 gauge link) then on to the Key switch.
May be a little larger Gy/Y wire coming off the key switch, 12 Ga, then tru the F-Link, then 16 ga, Gy/Y to HEGO.
There may be a splice where the GY/Y wire comes off the key switch, one wire goes to the F-link,and the other goes to the fuse box, all GY/Y in color.
#93
There may be a splice where the GY/Y wire comes off the key switch, one wire goes to the F-link,and the other goes to the fuse box, all GY/Yin color.
#94
#95
Well of course I got excited too soon. The f-link had continuity across it so that wasn't the issue. What I have found surprises me tho. I tracked the wire from the HEGO and had continuity all the way up until the firewall plug (huge connector). When I checked the interior side of the plug, I found that the matching GY/Y wire was nowhere to be found. It was missing. Checked the wires from the fuse panel side; (Fuse 5) is where the GY/Y wire appears and is connected to two purple/orange (maybe purple/red). The GY/Y wire coming from the fuse panel connects to the fuse link and splits into two GY/Y wires. I have tracked one to what looks to be a square connector going to the steering column (I'm assuming it runs to the ignition). The other gets lost into the dash somewhere, I couldn't track it without removing the entire dash. Does this sound right??? I found where one of the Purple/orange wires connects to the firewall plug and I am tempted to splice the engine bay side GR/Y with the Purple/orange wire to see if that gives the sensor power
#99
I didn't pull the entire dash off and the wire bundle went up under the top of the dash which was out of reach for continued tracking. If I had to guess it looked like the bundle was going to the radio/air controls/etc. If I could have pulled the entire dash off it would have made the job a lot easier but the weather is nasty with this storm front rolling in (perfect deer hunting weather, couldn't keep this off of my mind though) and I'm doing this in my driveway by myself. I'm literally losing sleep over this truck haha
#100
It may be too big of a job to fix that, so you could tap into the wire that; “gets lost into the dash somewhere“ , and run it out to the wire on the outside plug.
#101
I went ahead and spiced an inline 30 amp fuse from the large diameter GY/Y on the engine bay side to the Purple/Orange wire on the engine side and it ended up removing the 41 code from the KOER test. Everything passed! I measured mid 14 volts (my battery is bout shot) at the O2 sensor heater wire!! I also checked voltage on the signal wire at the computer and got .8 volts idling about 950-1000 rpms. Revved it up at the throttle body aiming around 2000 rpms (by ear so not very accurate) steady and it bounced around .3-.6ish volts. It's running a lot better now when I have it with the timing at around 10 degrees (i will verify tomorrow with the timing light) and the Spout in than it did....but still stumbles under a load. Not near as bad but still does pretty bad. I have noticed some of my vacuum lines are a little dryrotted so I've ordered some new hoses and they'll be here Wednesday. In addition to the hoses, I've ordered a new cap and rotor button and new plug wires. I feel good about the vacuum lines helping
#102
#103
I had a hard time finding the correct adapter for mine too, I was about to order one online because every rental kit from the auto parts stores in my arear had the adapter missing. I was lucky enough to find out my mechanic neighbor had one. You might have to order one online.
http://www.jegs.com/i/JEGS-Performan...41046/10002/-1
#105
I have looked everywhere online and cannot seem to find one. I must not be searching correctly. I'll take another look today. Jegs has one that is a "kit" that is for mounting to a 5.0 fuel rail. Think it will fit?
JEGS Performance Products 41046: Fuel Pressure Gauge Kit White | JEGS
