Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford C900
Old 09-25-2017, 07:52 AM
Dhenry113's Avatar
Dhenry113
Dhenry113 is offline
Ford C900
Started this thread to learn more about my truck. I am looking for some body parts for the cab. My steps are rotted and need to replace the. Any help would be greatly appreciated.
Old 09-26-2017, 09:11 AM
NoFrod's Avatar
NoFrod
NoFrod is offline
Learn
Post your V.I.N. or lots of basic data before folks can be of much help.
Old 09-26-2017, 05:22 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
What year is it??? Posting the VIN would be a big help.
Old 09-26-2017, 08:10 PM
Dhenry113's Avatar
Dhenry113
Ok my truck is a 1968 C900 with a 534 gas engine. Standard trany with a hydraulic clutch. The truck is equipped with air brakes. My steps a little rottted and I need to repair them. Over all the truck isn't in to bad of shape.i have found a place where I can get a lot of parts but the steps.
Old 09-26-2017, 08:14 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,578 Likes on 1,288 Posts
Numberdummy will confirm, but I think in the step department, all those cabs were the same. So any C series could be a donor.
Is there a plate on the driver door with the VIN? It also has trans and axle codes.
Old 09-26-2017, 08:53 PM
NumberDummy
Old 09-27-2017, 05:41 PM
Dhenry113's Avatar
Dhenry113
C90LVM30301
Also trying to determine what axles are in it
Old 09-27-2017, 05:46 PM
Dhenry113's Avatar
Dhenry113
I have notice it looks like an Eaton rear axle, so can I presume the from would be the same?
Old 09-27-2017, 07:17 PM
85e150's Avatar
85e150
No. Axle codes are on that plate, not in the VIN.
Old 09-27-2017, 08:13 PM
Dhenry113's Avatar
Dhenry113
There is a tag on the pass door. I can see the rear axle stuff but not the front. Next time I am out by the truck I can get a picture of it.
Old 09-27-2017, 08:21 PM
Dhenry113's Avatar
Dhenry113
I can see the rear is a Eaton, but sure on the front
Old 09-27-2017, 10:39 PM
85e150's Avatar
85e150
I read "Ford 9000", a Ford made 9000lb axle.
Rear says Eaton with a 6.50 ratio.
Warranty plate looks like this, minus the paint:
https://cimg6.ibsrv.net/gimg/www.for...ea0fc8127d.jpg
Better pic:
https://www.ford-trucks.com/forums/a...1&d=1493865544
Old 09-28-2017, 12:57 AM
NumberDummy
C90LVM30301 // Also trying to determine what axles are in it.
C90 = C900 (gas).
L = 534 4V
V = Kentucky Truck Assembly Plant.
M30301 = 1971 (are you sure it's 30301?)
AXLE code stamped on the 2nd line-far right of the Warranty Plate, riveted to the left (drivers side) door face below the latch.
Pic of build sheet in post #10 has this front axle ID number: C7TA-3010-Y = This is a Ford 9,000 lbs. capacity front axle.
Old 09-28-2017, 11:49 AM
Dhenry113's Avatar
Dhenry113
This on the door
Old 09-28-2017, 12:02 PM
Dhenry113's Avatar
Dhenry113
Really appreciate your help. I've been told it's a 68 but the build sheet from young fire equipment says it's a 71.
Quick Reply: Ford C900
