1985 F-150 Coolant reservoir cap?
Old 09-23-2017, 11:12 AM
Cojamo83's Avatar
Cojamo83
Cojamo83 is offline
I’m having trouble finding what is supposed to cover the hole in my coolant overflow tank. I made one out of a rubber stopper but was wondering what the original looked like. The truck is a 1985 F150.
Old 09-23-2017, 04:24 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,103 Likes on 1,791 Posts
I have an 81 and from pictures, to lazy to go out to garage, it looks like yours is a little different.
My hose looks like it goes in at the top/side about were that hole is.
Now thinking of it how would I fill it or clean it out?
I have 2 and 1 has the top lid not fasten that I installed for now but when I was looking for other parts thru bins I found the 2nd but has paint on it but the lid is fasten.
I will have to look them over better to see just how you go about filling/cleaning it out.
Dave ----
Old 09-23-2017, 05:33 PM
Cojamo83's Avatar
Cojamo83
Cojamo83 is offline
To clean mine I used purple power degreaser and wrapped a paper towel around a coat hanger and scrubbed the sides through the hole on top. Cleaned up easy. The reason for the original post is because I have never seen the type of jug I have. All the ones o have seen are like yours where the hose goes through the top. My over flow hose attaches at the bottom of the jug.
Old 09-23-2017, 05:38 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
The overflow jugs are strange on these trucks. In fact, that is just what they are, overflow containers. They are not really coolant reservoirs. That round hole you are asking about had a permanent type black plastic plug glued in place, that looked much like a freeze plug. And the top is glued in place also. The only thing it's for is to contain any overflow from the radiator so it doesn't go on the ground.
Unlike a coolant reservoir, which has a fill cap, and has hot and cold fluid levels, and can be filled. I pulled my plug out just like yours is, and use a funnel to fill it so I can use it like a reservoir. I had another on my earlier truck where I broke the glue loose and could take the whole top off.
Old 09-23-2017, 05:42 PM
FuzzFace2's Avatar
FuzzFace2
Have you looked at LMC or Dennis Carpenter or maybe Rock Auto to see if they have any and what they may look like?
I wonder if the jug changed when they went from copper to alum/plastic radiators?
Dave ----
Old 09-23-2017, 06:28 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
Here are some photos of my 1986. The top cover is glue on.
Jim
Old 09-23-2017, 06:36 PM
Cojamo83's Avatar
Cojamo83
Cojamo83 is offline
Thanks for the replies. Guess ill just keep the rubber stopper in it. It doesn't leak and the washer pump works just fine so i couldn't justify replacing it. Especially with all the other fixing i need to address first. Jimrebel that is actually the first time i have seen one with the plug in it.
Old 09-23-2017, 07:49 PM
FuzzFace2's Avatar
FuzzFace2
Thanks Jimrebel for posting a picture.
That plug looks like a body hole plug, might be able to find one in the parts store to fit.
Dave ----
Old 09-23-2017, 09:45 PM
emgee's Avatar
emgee
emgee is offline
Here's a look at what I've found at my JY regarding the reservoirs:
Old 09-24-2017, 06:05 AM
FuzzFace2's Avatar
FuzzFace2
My 81 is like the one on the left/diesel one.
Now I see it has a 90* fitting where I thought the hose just went in and to the bottom?
Now it brings up a question of the one on the right.
When the system builds up pressure and the cap lifts it sends that pressure to the over flow how does it get out if it is sealed?
Dave ----
Old 09-24-2017, 09:52 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
The reservoir on the left is the style that was used on the 1980 - 1984 gas trucks.
The reservoir on the right is the style that was used on the 1985/1986 gas trucks.
The 1987 - 1991 models used a completely different style.
Old 11-29-2020, 10:57 PM
kolobcanyon's Avatar
kolobcanyon
kolobcanyon is offline
Mine has the same cap missing. My current solution has been to shove paper towel in the hole. Very stupid because fires n stuff
Old 11-30-2020, 08:48 AM
Max Capacity's Avatar
Max Capacity
Max Capacity is offline
Just ran out and took a photo of the yellow cap I put in the tank on my 86 F150 with a 302FI.
dasoundman
03-09-2014 03:53 PM
camodown
01-19-2012 07:40 PM
93 mix 'n match
1997 - 2003 F150
10-29-2010 11:50 PM
93nighthawk
Aerostar
09-20-2005 12:54 PM
olebrownford
16
02-16-2004 11:59 PM
Quick Reply: 1985 F-150 Coolant reservoir cap?
