88 Bronco 5.8
88 Bronco 5.8
I recently replaced the starter relay solenoid. The vehicle was running fine for a couple weeks, but now i have to bypass the relay again just to get her to start. Not sure if something else could be wrong?Maybe a loose wire or bad connection? She also starts with no key needed. And cant seem to find any decent diagram for basic under the hood components and wiring. Need assistance!
I havent a clue when its to the wiring and looking for diagrams for that and under the hood components. Plus anything to do with steering column assembly and wiring.
Welcome to FTE
This is an introduction forum. You are not likely to get many answers or help here. However is you would re-post your question in the 1978 to 1996 Big Bronco Section, you may get several responses.
Don't forget we have an international chapter too. You may find others, from PR, there.
That is my guess and response in the OP's other thread: https://www.ford-trucks.com/forums/1...nco-5-8-a.html
