Modular V10 (6.8l)
Oil pan drain plugs discussion
Old 09-22-2017, 12:25 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
I've seen people on here using the Fumoto valves, not sure how I feel about them. The other option I'm more likely to go is with a magnetic drain plug, I would also replace the crush washer with oil change. I've used and am currently using these on other vehicle I have with solid results. Keep in mind if the magnet is picking up large pieces more than fuzz you likely have some internal issues. I went ahead and included links below to the Fumoto valve, GReddy and Mishimoto magnetic drain plug.
One thing I do like about the GReddy is the flange on the bolt head it self, serves as a solid place for the crush washer.
https://smile.amazon.com/dp/B003T7XU...=1Y4EQ5SOF11EM
https://smile.amazon.com/dp/B008OZFP...d=1Y4EQ5SOF11E
https://smile.amazon.com/Mishimoto-M...J9MRY9HQ2HPH5S
Old 09-22-2017, 02:39 PM
sddesigns's Avatar
sddesigns
sddesigns is offline
Been using the Fumoto valve for 5 years now and love it, I don't put more than 3-4k miles on a year so I send my oil to Blackstone labs on my annual oil change. I get a pretty good report considering my driving is mostly short distances, with the annual 1-2k trip.
Fumoto Engine Oil Valve
Old 09-22-2017, 03:54 PM
Bently_Coop
I'm in the same mileage category, about 5k per year. If you're changing the oil annually at around 3-4k why do you send for a Blackstone report? Does the Fumoto help with sampling?
Old 09-22-2017, 05:46 PM
sddesigns's Avatar
sddesigns
Just like to keep up on any abnormalities that might crop up, and yes I start the oil flow when draining and wait a few seconds and collect it as its flowing as per the lab's directions.
Old 09-23-2017, 11:49 PM
IslandBlueV10's Avatar
IslandBlueV10
IslandBlueV10 is offline
I also have the Fumoto. I have the one you have pictured with the nipple on it. Best choice you could make. So easy to change the oil. I attach some clear tubing to the nipple then the other end into my container. With the clear tubing I can see the oil and watch for anything unusual. I also attach a magnet next to the drain. I remove the magnet when I drain the oil, then replace. I have used mine for probably 5 years with no issues. I have been through deep mud and snow with no issues.
Old 09-25-2017, 09:14 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
5 years on my Fumoto valve here with no issues, about 3 to 5 k miles a year nearly all of them towing.
Old 09-25-2017, 09:23 AM
sddesigns's Avatar
sddesigns
For a little more piece of mind going through some off road adventures, they have a small clip that goes over the release tab.
Amazon Amazon
Old 09-30-2017, 09:50 PM
CalEx4x4's Avatar
CalEx4x4
CalEx4x4 is offline
I've had the Fumoto on my 4x4 Excursion for about a decade. Never knocked it off, or even lost that little drain hose that I keep attached to it. No issues on my 2006 E-450 either. It sits lower, but isn't off roaded (not on purpose, anyway)!
Fumoto on 4x4 Excursion with V-10
Old 11-07-2017, 03:44 PM
geekwithoutacause's Avatar
geekwithoutacause
geekwithoutacause is offline
The fumoto is great. Used it on several vehicles, never an issue. So much easier to drain oil. Dump directly into an old container. No splashing oil, no hot oil hitting your hand. Downside is that you still need to change the filter and some oil will spill. Still WELL worth it.
Old 11-09-2017, 12:27 PM
truckfella's Avatar
truckfella
truckfella is offline
F106 (same as pictured above) is the model that fits our rigs?
Old 11-09-2017, 01:06 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Yes, F106 for the V-10, F106N if you want the nipple on the outlet that allows for attaching a hose to drain into a container.
Old 11-09-2017, 02:13 PM
truckfella's Avatar
truckfella
Perfect, thank you.
i-w
02-23-2020 11:38 AM
WolverineXcursion
01-18-2018 09:12 AM
2009kr
2017+ Super Duty
08-01-2017 12:34 PM
superduty4x4
21
07-31-2008 12:38 PM
mitchntx
04-26-2007 11:09 AM
Quick Reply: Oil pan drain plugs discussion
