351w positive identification please (I read the sticky, still confused)
Just picked up what I really hope is a 351w. The valve cover bolts look correct.
Seller said he pulled it from a 1978 f100 but I think the casting says 1979 Galaxy?
By the starter facing down on the block I get:
D9AE 8015 - ED
Does that say 1979 Galaxy engine?
After that it says "76"
Below that is IK22 or LK22, hard to read.
Intake manifold has;
D5AE-9425-DC
And
18728548
And from what I understand you can't verify that it's a 351w from that number, is that correct?
Thanks!
- Joe -
D9AE 8015 - ED
D5AE-9425-DC
And
18728548
Thanks!
- Joe -
"A" does not denote a Galaxie, but rather a full size Ford car. Be that as it may, the "A" does not mean it was installed in a full size Ford at the factory. These are the Engineering characters used to assign the engineering costs to a particular vehicle line (bean counter stuff) D9 would indicate that it's a 79 or later 351W block. The 1K22 is the date code, it was cast Oct 22, 1981. And yes, it's a 351W block , as none of the 302 blocks had an "A" in the Engineering numbers (that I'm aware of) Your numbers should read D9AE-6015-ED, 6015 is the part number for an engine block, not 8015
thanks, very helpful!
Of course, more wire brushing would have helped. I should have put that together on my own, duh. I'll blame lack of sleep, I slipped a disc in my back and I've had a couple hours sleep in the last four days, not thinking so clearly anymore..
So the date code of 1979 is just the design of the cast, not the exact year? It's after 1981 then, any idea the range? Like 82-85 or similar?
Thanks guys!
Are you shopping for a new flywheel ? Or used ? New shouldn't be a problem. If used my advice is to steer clear of a used flywheel. Nothing but trouble there. Both in how it could have been abused and how many times it could have been resurfaced before you get it. You'll need to also make sure it's compatible with the pressure plate you use.
brandosford
01-20-2012 09:53 PM
dcf1970
20
10-01-2009 11:21 AM
78 Ranger
11-11-2005 07:12 PM
