2003 Expedition Vacuum line trouble
2003 Expedition 4.6 liter 4x4. 225k miles. I'm pretty sure my 4wd works ok (I know 4 lo does) my ac blows cold but the ac vents don't switch to feet. Is this a vacuum line problem? I've checked what seems like every vacuum line in the engine bay and all I found is a broken curved hard plastic line, and 2 spots where it looks like a line should be feed. Does anyone have any info to help me out? It's greatly appreciated.
Curved hard plastic line that's on top of the paper
Not sure if a line is supposed to plug into that (heater valve?) cylindrical thing in the center
Is a vacuum line supposed to go into that third boot? This is right above passenger tire front
Well, the one up high is supposed to plug into your hot water valve. I see it's not.
Plug that in and you should get vent control back. The dash vacuum supply line should connect to it's source up in front of the throttle body.
It looks like someone has replaced your PCV vacuum elbow tube and PCV valve ? They might've popped something loose while doing that.
You'll probably have to go find a 4x4 Expy of that year and look to see where that other line connects. Mine's a 4x2 and I don't have that line.
-Mike
Hot water valve ....
Dash vacuum supply source line ....
-Mike
Thelionwarrior
39
05-15-2018 04:14 PM
tofino
10-12-2014 04:19 PM
ScottyDsntKnow
1997-2006 Expedition & Navigator
06-11-2011 11:17 AM
hydrology_joe
06-09-2010 12:43 PM
