Any suggestions? Fuel pressure is 35 off 38 running, Brand new MSD spark plug wires, all new ignition system. And new IAC and TPS and MAP, When it fires up it idles high at 2k then starts bucking and jumping from 500 to 2500 rpm and the exaust smells like straight gas, Every once in a while it will be normal and if you drive it you lose a cylinder or 2 and it lunges up and down the road. I need this truck for next weekend any suggestions? Codes all cleared up mysteriously except for 67 CM 29,33
ok so i cleared codes got it fired up and ran it for 5 mins got codes KOER 4 12 13 21 23 25 44 53 72 73..Starting to wonder if the rebuilt computer is bad? I grabbed a new map sensor and it made zero differance.
Ok my book said 35-40psi, And nope flashes 4 times then nothing until code 12 done this 4 or 5 times today..im really wondering if this computer is screwy.
Very rare for the idle pressure to be 35 PSI. Most report, and my old truck as well, 30 to 32 PSI.
Once again, there is no Code 4. No single digit codes whatsoever.
