2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Inventer Off When Door Open
Old 09-20-2017, 02:39 PM
Roly Poly's Avatar
Roly Poly
Roly Poly is offline
Noticed that when the door is open the Inverter is powered off, unless you press the brake pedel then the inverter powers up again.
Is there a configuration setting, maybe via Forscan to leave the inverter powered up even when the door is open.
All started when I plugged a trouble light into the inverter, everything worked until I open the door.
Roly
Old 09-20-2017, 05:27 PM
f350ktm's Avatar
f350ktm
f350ktm is offline
That's a new one to me, thanks for posting the info.
No help here for changing it however.
Old 09-20-2017, 06:24 PM
crewzer's Avatar
crewzer
crewzer is offline
Question
A new one on me as well. Here's a pic of our truck's inverter powering a lamp with the engine running and the rear driver-side door open:
Jim / crewzer
Old 09-20-2017, 08:03 PM
Roly Poly's Avatar
Roly Poly
The plot thickens...
If I'm the driver seat, truck running, light on. (using 120v trouble light)
Open driver door, 5 sec latter - light off
Press brake peddle / door open - light on again (as long as I hold the pedal)
release pedal - light off
Close driver's door - light still off
Press brake pedal - light on and stays on
Reach back and open a rear door from the inside - light on and stays on.
I'm now wondering if some of the forscan changes are causing this behavior, like (police mode / secure idle). Just a thought.
-Roly
Old 09-20-2017, 08:14 PM
nbayless36's Avatar
nbayless36
nbayless36 is offline
-Roly
do you have Lincoln style auto fold mirrors enabled? I don't have an answer for you but that modification works off the drivers door
Old 09-20-2017, 11:54 PM
f350ktm's Avatar
f350ktm
f350ktm is offline
-Roly
OK, now you've done it.
This is going to bother me until a resolution is found.
I have difficulty letting go of this sort of thing, a personality defect I am constantly at battle with.
Reminds me of torturing my 2 boys 25 yrs ago when they were just kids. A couple of nights a week I would read a short story to them at bedtime from a book titled "100 Malicious Little Mysteries".
Each mystery story was just a few pages long and left the reader with the challenge of solving the mystery presented in the story. Rarely the boys solved the mystery right away. Other times I would let them think through the information, present possible solutions, then read them the actual solution in the back of the book.
If it had been a tough day at the office and I was in a particularly cantankerous mood I at times chose to make them wait until morning for the solution. On occasion they would creep downstairs after being put to bed begging for the answer. A great tool for stimulating logical thinking patterns for kids.
My personality defect has worsened with age, must be pay back for torturing the boys.
I have a King Ranch CCSB as yet without Forescan (that will change as soon as time allows). I'll run your tests and see what mine does.
Old 09-22-2017, 10:13 AM
f350ktm's Avatar
f350ktm
f350ktm is offline
OK, so I tried mine.
The only factor determining whether or not the inverter is on is whether or not the engine is running.
Engine on = inverter on
Engine off = inverter off
Full accessory mode = inverter off
Again, no Forescan on this truck yet, not sure if that is a factor either however.
Old 09-25-2017, 10:39 AM
MagicMtnDan's Avatar
MagicMtnDan
MagicMtnDan is offline
I see FORScan is mentioned in this thread. As you likely know, using FORSCan you can enable the power plugs to stay on 24/7.
bentheplumber
1999 to 2016 Super Duty
16
07-05-2007 12:04 AM
dannunz
07-31-2005 06:13 PM
bigexpo
1997-2006 Expedition & Navigator
06-23-2005 10:15 AM
bager
1997 - 2003 F150
03-17-2004 06:55 PM
minishtr
Aerostar
01-21-2004 09:08 PM
Quick Reply: Inventer Off When Door Open
