Radius Arm Rubbing with Nitro 37's
As I mentioned in my "new here" post, I purchased a used 2022 F250 with 37s and it looks like the previous owner didn't lift the truck. At full lock the tires rub the radius arms. Are there any long term concerns I should have with the suspension components being damaged? Is there anything I can do to reduce or prevent the rubbing without an actual lift? Spacers etc and if so are there any recommendations? Thanks in advance for any help.
The following users liked this post:
I have rub marks on my bds radius arms to prove it.
what I would do is just get aftermarket wheels now. Take your time and find a set you like (took me forever but I finally found a set I liked) and I couldn’t be happier
im not a fan of -77mm 14” wide wheels with rubber band tires but if you go with a 10” wide wheel I think it’s a real nice look on a SD and it would eliminate your rub. Just don’t go too wild with offset
MBBFord
18
07-21-2005 10:43 AM
